VideoHelp.com Forum
  1. Hey,
    I have some MJPEG vids that I'm trying to open in VDub. They used to open fine as VDub would use its internal MJPEG codec. Though after installing the Panasonic DV codec, VDub is not opening my MJPEG files anymore. It gives an error: "the source image format is not acceptable" and returns -2 for an error code. I then look at the file properties and it lists "Panasonic DV" for the decompressor. Just wondering how I can fix this. I tried uninstalling the Panasonic DV codec though Windows multimedia settings and it still lists the Panny DV codec as the decompressor. Any ideas short of reinstalling Windows.
    - Mike Young
    My Clay Animations
  2. Member hiptune's Avatar
    "system restore" if you are running XP, that should do it.
    Files > Programs > Assesories > system tools > System Restore.
    Then pick the day BEFORE you installed the Panasonic Codec.
    Jeff
  3. I run Win2K. Guess I should have mentioned that. My bad. I guess I was also hoping for a more direct solution. I appreciate the suggestion though. Maybe I need to find a VDub expert. Any other ideas?
    - Mike Young
    My Clay Animations
  4. Myoung,
    if you don't have installed any other mjpg codec into your system, install the PICVIDEO codec which will be automatically assigned as the primary mjpg codec (if not, then you'll have to set it manually as the primary codec). After that i believe that you will not have any problems viewing your mjpg clips.
    Cpu power is never enough
  5. Thanks! I'll give that a try. I also see that I can just frameserve to VDub using AVISynth and DirectShow, though that's not much of a solution.
    - Mike Young
    My Clay Animations
  1. Re-compressing many times with lossless codec in Vdub introduces colorbleed
    By Mephesto in forum Newbie / General discussions
    Last Post: 19th Feb 2012, 06:39
  2. Replies: 3
    Last Post: 21st Jan 2011, 14:10
  3. Anybody used FFDshow Mjpeg codec for capture?
    By davexnet in forum Capturing
    Last Post: 31st Oct 2010, 00:27
  4. Low compression codec, other than MJPEG.
    By blitter2 in forum Capturing
    Last Post: 2nd Dec 2008, 18:20
  5. Ricoh Caplio R5 MJPEG and Video Studio codec query
    By Pronto71 in forum Video Conversion
    Last Post: 19th May 2007, 21:30
