I am trying to play (and encode) an mpeg4 movie with ffmpegX. It will play with sound using the old k-version of ffmpegX (but not encode), but the latest two versions (l, m) will not find a sound codec. ffmegX gives the following
AUDIO information: 0x6134706d 32000Hz stereo. Anyone know what the problem is??
Thread: ffmpegX problem with sound
moving to ffmpegx forum
Did the old version recognize the audio codec with its name?
I manged to screw up my old account so I could not answrwe in this forum, but this has happened
>> If you mean the info presented at the top line, it says the same, i.e.
>> AUDIO: 0x6134706d 32000Hz stereo
> OK so no more information appear in the old version..
> can you open it in quicktime and get more info?
>> pressing the info button will not give any result in old or new versions.
>> Another thing that differ is that when I shut down the mplayer window showing
>> the movie it will give a crash report in the new version "The application
>> mplayer has unexpectedly quit ..." but not in the old.
> never close the mplayer window by clicking the red circle
> use the RETURN key instead
No I cannot open it in quicktime, there is some mpeg4 stuff quicktime
says it doesn't handle. Thats why I wanted to convert it using ffmpegX in the first place, but I get nowhere. I even tried some windows mediaplayers with no luck.
I have same problem with MPEG-4 sound.
Seems new version of FfmpegX have problem with this sound format.
ffmpegX Convert but no sound
By Ma_Long in forum ffmpegX general discussionReplies: 17Last Post: 7th Jan 2012, 07:42 -
Louder sound via ffmpegX
By maruz in forum ffmpegX general discussionReplies: 2Last Post: 2nd Oct 2009, 04:05 -
How to disable End of Conversion sound on ffmpegX
By BS0D in forum ffmpegX general discussionReplies: 2Last Post: 16th Nov 2008, 19:46 -
ffmpegX 0.0.9 - no sound in the output of a transcode
By mattr in forum ffmpegX general discussionReplies: 2Last Post: 21st Sep 2008, 02:56 -
ffmpegx, avi loses sound...
By tomyknoker in forum ffmpegX general discussionReplies: 3Last Post: 17th Sep 2008, 13:29
