VideoHelp.com Forum
  1. When I try to write to the hard disk I get the following error (with large amounts of data):
    Quote:
    Windows - Delayed write failed
    Windows was unable to save all the data for the file .... The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere
    I've got this when attempting to do any video editing. It locks up my computer and I usually have to reboot. I have check for virus with Norton, no virus. Checked Adware with Adware and Search and Destroy. Nothing. And my Windows Upsates are current. Does anyone know why thias is happening. I heard that Microsoft will be releasing an upgrade for XP next month, is this a common problem? My computer; 2.4 Pent 4, 1024 DDR ram, 200 gig and 80 gig 7200 rpm hard drives. Nvidea 64 mmg graphics card-This shoud be able to handle the tasks I have been attempting to do!
    Silent Assasin
    Have you tried MS web site, google or Windows Help? You might be surprised what you find.
  3. Yep, I looked all over and either I have been informed that My enabling Cache might be the problem (but the drive I'm saving on is a 200 g WD harddrive that doesn't give me the option to uncheck the enabling cache), to checking my bios, but why would my bios have changed?
    Silent Assasin
  4. I'm a Poll Super Moderator johns0's Avatar
    What could be happening is bad ram,bad power supply,bad sectors on the hdd,faulty hdd,video card over heating,cpu overheating,motherboard going faulty,windows os going south,you will have to do some testing to see where the problem is,turning off the cache isnt going to help in the long run.you will still have the problem.
    Ben Johnson-I didnt take any stereos!
  1. Windows 7 AC3 Problems
    By eon_designs in forum Video Conversion
    Last Post: 20th Apr 2010, 04:07
  2. Replies: 4
    Last Post: 28th Mar 2010, 20:54
  3. Still having driver problems with windows 7
    By intheory in forum Newbie / General discussions
    Last Post: 16th Mar 2010, 18:18
  4. Windows 7 problems
    By SEK in forum SVCD2DVD & VOB2MPG
    Last Post: 15th Nov 2009, 16:33
  5. VLC problems in Windows Vista
    By 1234567 in forum Computer
    Last Post: 8th Oct 2008, 16:45
