I am running Win2000.
I have firewire card installed and it is working. When I plug in the camcorder, the PC doesn't see the camcorder.
Any ideas on what to check?
Bad cable? Card slightly risen from slot (check device manager)? Does it work with software supplied with camcorder?
during my search for GS11/15 reviews i noticed someone with the same problem...he solved it by turning everything off (camera+pc), then turn the camera on in PC mode, then turn on the PC.
Panasonic PV-HD1000 firewire out?
By Des in forum CapturingReplies: 5Last Post: 14th Oct 2011, 14:01 -
Panasonic DV Firewire problem
By darrenkarp in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2010, 13:28 -
Problems using a Panasonic DV camera (NV-DS50) in my firewire
By Duck_Plumber in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 10th Apr 2010, 09:10 -
Panasonic PV–GS19 firewire connection - computer can't read it
By rbenjamin in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2007, 09:48 -
Panasonic PV-GS15 Capturing Problems
By brad86_mx in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 10th May 2007, 15:38
Statistics
Newest guides
Latest tool updates
New media comments
