I hope someone can direct me to the right site to find out how to fix this. Was using Sefy's tips and brought my file into VirtualDub to save the audio as a wav file but this error message came up:
"VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 24742 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder (bitrate: 97.1 +or - 11.7 kbps)."
Do I need to change any settings in Virtual Dub or TMPGEnc or anything? In other words, what do I do with the above error message?
Thank you for any help!
Thread: Virtualdub error message: HELP!
In virtualdub, on the audio tab, select full processing mode.
Under audio, select the compression, then you will have a choice of compression methods.
Select no compression. Then go back to the audio tab, select conversion.
If the file sampling rate is already 44,100hz, do nothing.
If the sampling rate is not 44,100hz, then select 44,100hz
On channels, make sure it is set on stereo
On precision, select 16bit
Then go back to the file tab and select save as wav, and give it a name, and select where you want to save it, then save away.
You should be all set.
Thank you so much for that! I'm giving a try now and will let you know!
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
Statistics
Newest guides
Latest tool updates
New media comments
