I have a friend who installed a fresh copy of XP but since he has dial-up it'll take forever for him to download all the critical updates and install them before using his comp without getting infected.
Since I have DSL I was wondering is there an all-in-one exe/patch so I can download put it on CD and just install it on his? The recommended updates would be nice too but for now I'm just looking for the critical.
Results 1 to 9 of 9
Thread: Critical Updates
No
You must download the service pack, the update rollup, and all the updates since then.
It already has SP1... I just need everything from SP1 until now... What's this rollup you mentioned and where can I get it? Does it contain all the critical updates until now?
No.
The update rollup 1 came out I think last year, or the first of this year.
All the other updates are separate.
You must download them individually.
Get them from windows update or microsoft's download site.
go to the windows update site and click on the update catalog (if you don't see it, click on personalize and chech the first one)
Now click on OSs
Click on your flavor of OS
Click on critical updates....
Click on add to the ones you want
Click on your basket
Click on browse to select the location you want to save them to
Click on download now
Burn to a CD or DVD and install on other computer
OR
Order the security CD from MS and then just add the thing after that published date
There is a magazine out of Great Brittan called "Windows XP' that always has a few free full programs, many shareware and demo programs and lots of game demos (usually on a DVD). It occasionally offers a 'roll up' of critical updates, upgrades to Media Player, and upgraded drivers for printers, video cards, etc. The price is 13.95 (CD version) and 15.95 (DVD version). It's worth a look every month as it sometimes offers older versions of good programs (with the opportunity to upgrade to the new for a discount price, there's always a catch). I always find it at Barnes & Noble and most computer stores that have a magazine section.
If it works, don't fix it.
what are people using at work to do these updates
do you have to visit each PC and run the updates manually
do you do them after work hours
when it tells you to reboot , do you really have to or can you continue with the other updates and then do one reboot later
You can go through the server to have the server dispatch these updates to the client workstations. You can set up an answer file, and some techs do this at night. Good time to do backups as well.
Microsquash must of been getting slammed yesterday.. the Catalog Update tool would not work. Will try again today.
Critical Error (Event ID 41 Kernel-Power) causing win7 BSOD & reboots
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 28th Mar 2012, 15:19 -
Corrupted WMV Files - Header is missing critical data
By Avide in forum Video ConversionReplies: 4Last Post: 6th Jul 2011, 04:01 -
Critical Speed Loss
By saurio in forum DVD RippingReplies: 2Last Post: 21st Jun 2010, 14:17 -
Should I be concerned after "critical issue" on boot up for XP?
By yoda313 in forum ComputerReplies: 22Last Post: 3rd Jul 2009, 12:11 -
AVG 8 updates?
By wulf109 in forum ComputerReplies: 2Last Post: 3rd Feb 2009, 09:49
