Hi All,
I am using ffmpeg to convert my dv video to DVD Video. For the same I
have used following command:
ffmpeg -i INPUT/0000.avi -vcodec mpeg2video -r 25 -s 704x576 -b 5000
-ab 224 -ar 48000 -ac 2 -hq -deinterlace 0000.mpg
$ ffmpeg -i INPUT/0000.avi -vcodec
mpeg2video -r 25 -s 704x576 -b 5000 -ab 224 -ar 48000 -ac 2 -hq
ffmpeg version 0.4.8, build 4717, Copyright (c) 2000-2004 Fabrice Bellard
built on Jul 8 2004 17:14:40, gcc: 3.3.3 20040412 (Red Hat Linux 3.3.3-7)
Input #0, avi, from 'INPUT/0000.avi':
Duration: 00:14:30.4, bitrate: 29829 kb/s
Stream #0.0: Video: dvvideo, 720x576, 25.00 fps
Stream #0.1: Audio: pcm_s16le, 32000 Hz, stereo, 1024 kb/s
Output #0, mpeg, to '0000.mpg':
Stream #0.0: Video: mpeg2video (hq), 704x576, 25.00 fps, q=2-31, 5000 kb/s
Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
AC EOB marker is absent pos=640kB time=127.0 bitrate=5248.1kbits/s
AC EOB marker is absent pos=68
frame= 7172 q=3.4 Lsize= 183604kB time=286.0 bitrate=5259.8kbits/s
video:175075kB audio:7819kB global headers:0kB muxing overhead 0.388311%
The problem that is coming up is that I dont have the full length video
in the output file. The length of input file is 14:30 min, but that of
output file is around 4:46 mins only. Any clues as what may be happening
here?
TIA.
-McLinux
One thread is enough.
https://www.videohelp.com/forum/viewtopic.php?t=229699You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Hi Moderator,
I was myself not sure as to which forum this question be fit into, hence in order to get most probable answers, I posrted on both the posts.
Thanks for notifying.
-McLinux -
Well this one got fixed thorugh a patch sent by Roman.
Thanks Roman.
The same is given below:
Code:--- /home/rs76089/tmp/ffmpeg/libavformat/avidec.c 2004-07-13 17:10:06.000000000 -0700 +++ libavformat/avidec.c 2004-08-03 18:22:08.000000000 -0700 @@ -49,6 +49,7 @@ int64_t movi_end; offset_t movi_list; int index_loaded; + int is_odml; DVDemuxContext* dv_demux; } AVIContext; @@ -128,6 +129,10 @@ goto end_of_header; } break; + case MKTAG('d', 'm', 'l', 'h'): + avi->is_odml = 1; + url_fskip(pb, size + (size & 1)); + break; case MKTAG('a', 'v', 'i', 'h'): /* avi header */ /* using frame_period is bad idea */ @@ -363,7 +368,8 @@ { AVIContext *avi = s->priv_data; ByteIOContext *pb = &s->pb; - int n, d[8], size, i; + int n, d[8], size; + offset_t i; void* dstr; memset(d, -1, sizeof(int)*8); @@ -377,19 +383,12 @@ for(i=url_ftell(pb); !url_feof(pb); i++) { int j; - if (i >= avi->movi_end) { /* Let's see if it's an OpenDML AVI */ - uint32_t tag, size, tag2; - url_fskip(pb, avi->riff_end - url_ftell(pb)); - if (get_riff(avi, pb) < 0) - return -1; - - tag = get_le32(pb); - size = get_le32(pb); - tag2 = get_le32(pb); - if (tag == MKTAG('L','I','S','T') && tag2 == MKTAG('m','o','v','i')) - avi->movi_end = url_ftell(pb) + size - 4; - else - return -1; + if (i >= avi->movi_end) { + if (avi->is_odml) { + url_fskip(pb, avi->riff_end - i); + avi->riff_end = avi->movi_end = url_filesize(url_fileno(pb)); + } else + break; } for(j=0; j<7; j++) @@ -408,6 +407,13 @@ url_fskip(pb, size); } + + //parse JUNK + if(d[0] == 'J' && d[1] == 'U' && d[2] == 'N' && d[3] == 'K' && + i + size <= avi->movi_end) { + + url_fskip(pb, size); + } //parse ##dc/##wb n= (d[0] - '0') * 10 + (d[1] - '0');
Encode with FFMPEG with multiple input files...
By RogerTango in forum Video ConversionReplies: 3Last Post: 20th Jun 2011, 01:12 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 10:13 -
Burning 10 full length vids into a DVD9
By maggot6sic6 in forum Newbie / General discussionsReplies: 18Last Post: 23rd May 2008, 23:06 -
FFMPEG and input A/R
By nic2k4 in forum Video ConversionReplies: 1Last Post: 14th Nov 2007, 19:39 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 20:07
