VideoHelp.com Forum
  1. I have a Toshiba SD-1600. I can only assume it is region 1. I have read the info on this site on my model in the hardware database and I can see that there is no "software" way to make the player read other regions (though there is one mod kit out there)
    However, my question is even more newb than that. I know that the player will not read region 2-6, but will it read region free (0) DVDs? The hardware database does not make this point clear and I am frankly without a clue.
    The reason I ask is that I am interested in buying a DVD set of the original Star Wars trilogy off eBay and they are "region free"
    Any help qould be appreciated.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    If they are 'region free', how do you know they aren't low quality copies of the original? I may be wrong, but I am not aware of any 'region free' originals.
  3. Member steveryan's Avatar
    The Star Wars dvd's are not released until september so these on Ebay are best avoided.
    @redwudz There's loads of region 0 dvd's, the vast majority of porn dvd's are region 0, according to my mate anyway.
  4. Member Grimey's Avatar
    sure
    jmcmike, try this: http://www.videohelp.com/dvdhacks.ph...Toshiba+SD1600
  5. FYI everyone, I own the widescreen VHS release from the early 90's and I am basically trying to archive them to DVD but getting poor results due to tape deterioration.
    redwudz: I don't know about the quality but I am researching it.
    steveryan: The DVDs coming in the fall are not the original versions but will rather be further enhanced Special Edition versions. I am looking for the originals.
    Grimey: Thanks. I checked that but there is no help for my player.
    I think I will be OK anyway. My player has no problem with the DVDs I have burned so far (with Nero Vision Express) and I assume they are region free, so I should be OK.
  6. What's called "region free" is a DVD that can play in all regions, i.e. it has no region prohibitions. It will play just fine in your Toshiba.
    If I were you, I wouldn't bother modifying the player. The whole idea of the region codes is to prevent poor us outside of region 1 from buying much cheaper DVDs released many months earlier in your region.
  1. Newbie question for creating a DVD
    By DaBooch in forum Newbie / General discussions
    Last Post: 28th Mar 2010, 17:51
  2. Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
    By jteselle in forum Newbie / General discussions
    Last Post: 3rd Nov 2009, 11:49
  3. Newbie-Question about DVD Player
    By sohancool in forum Newbie / General discussions
    Last Post: 20th Mar 2008, 23:00
  4. Newbie-DVD format question
    By plemal in forum Newbie / General discussions
    Last Post: 14th Feb 2008, 14:06
  5. DVD Decrypter Region Question
    By nickolasj80 in forum DVD Ripping
    Last Post: 21st Jun 2007, 19:26
