VideoHelp.com Forum
  1. Hi folks
    i am trying to rip a sopranos disc that has 2 episodes on it, but i can only seem to get the first episode and a documentary that is also on the disc. i am using smartripper then dvd2avi then TMPGenc.
    sorry if this is a simple question but i am relatively new to this.
    thanx in advance
    digipal
  2. You'll need to expand and select the tracks you want. Just look for ones that are larger than 1700MB. Also, note that when you rip the VOB files will be missed numbered, and either the first or last vob might not contain any data.
    So rename them as necessary.
  3. thanx for the speedy reply, but i am pretty new to this so can i ask u to explain what u mean by expanding and selecting the tracks i want.
    thanx
    digipal
  4. I believe SmatRipper automatically defaults to the largest group of connected VOB files (usually the movie) and ignores the rest.
    Click on the Files button and select all the tracks.
  5. Well you don't need to do them all.
    When you run smartripper you'll see a list of tracks, and one of them will be highed as the movie (the largest track).
    Think of it just like windows explorer, click the + button next to the track to expand it, and then see what the runtime is. The Sopranos are 50-60min/eps so you can look for tracks that are listed at 1800MB of greater (the 350MB tracks won't have the movie in them).
    Then highlight and rip each track you want (make sure to give them different names).
    Now, soprano's specific. Normally when you rip you get xxx_1.vob, xxx_2.boc, etc. But when you rip the Soprano's you'll get:
    xxx_1.vob
    xxx_2.vob
    xxx_6.vob
    xxx_8.vob
    And there's a good chance that either the first or last VOB (maybe both) won't have any actually data in them. So you need to play each VOB file (media player can do this), erase the VOBs w/ no data. Then re-name each vob in increasing numerical order, otherwise dvd2avi won't read/load them all.
    Also don't be surprised if when you play the VOBs in media player if the total times don't add to ~55min (ie. the runtime, normally one of them will read as 1:40) and you will hear all the audio tracks played at the same time
  6. vejita-sama thankyou very much for your help, i have now managed to extract both episodes from the dvd, thankyou to whoosh25 for taking the time to reply.
    both top guys.
    thanx
    digipal
  1. Need to burn TV episodes to DVD
    By harishkumar09 in forum Authoring (DVD)
    Last Post: 18th Mar 2012, 13:40
  2. Best way to rip and encode TV episodes to DVD?
    By MackSwagga in forum DVD Ripping
    Last Post: 28th Mar 2011, 20:16
  3. How To Rip TV Show DVD Into Episodes
    By drtalk in forum DVD Ripping
    Last Post: 15th Nov 2009, 13:42
  4. DVD episodes to MPTS
    By waveqam in forum Video Conversion
    Last Post: 15th Apr 2009, 16:37
  5. How do you author many episodes to 1 DVD-R?
    By 1980sumthin in forum Newbie / General discussions
    Last Post: 2nd Nov 2007, 22:49
