I need a region free player that will convert PAL-NTSC.. any recommends?
u can get alot if not most dvd players mod chipped for multi-region plus dvd players will usually just output pal or ntsc and not convert, it's the tv that needs to be capable of pal or ntsc playback
http://www.cyberhome.com/
You want the Cyberhome CH-DVD 500
Also the JVC models are really nice here:
http://www.hkflix.com
Good Luck!
- John "FulciLives" Coleman
P.S.
The Cyberhome website seems to be down. It does this often hehehe
I have a Cyberhome CH-DVD 500 and it is great for PAL to NTSC but it does have some "quirks" so I wouldn't use it to play burnt media with for instantance. In other words shouldn't be your only DVD player.
I've always heard really good things about the JVC models especially when using component outputs to do 480p if you have a TV that can handle that."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I think that's one of the tricks.. the deal is, I have two movies I will pick up that are Region 2 that I can't buy Region 1 (they don't exist R1
But they are of course, PAL.. now, if a dvd player isn't region free, I can of course, find one that supports Dual Layer discs, now that I've finally got a bunch of blanks in, and can *migrate* them that way.. but would still need one that did the PAL-NTSC conversion so it'd play on my Sony HDTV box..
yes, the Cyberhome is a PAL/NTCS player that outputs NTSC, and it is region free to boot!
The box says region 1, but the region 2 disc played perfectly.
Jeff
Any USA model JVC can convert PAL to NTSC but only if the disc is region free since it is locked to region one.
But that website I quoted earlier (HKFlix) has modded JVC DVD players that are region free.
I don't think anyone has a good grasp yet on the whole DVD+R DL thing yet. So far there are many issues.
So chances that a JVC can play a DVD+R DL disc is not too good I'm afraid.
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 09:28 -
Does making a dvd player region free also allow PAL to display on NTSC?
By dizmack in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2010, 19:50 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 18:48 -
Region Free/ Ntsc PAL Compatible
By veryconfused in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Nov 2009, 18:53
