  1. Hello,
    I've got lots of MPG2 528*576 files from my SkyStar DVB PCI Card. Work fine when authored with DVD Lab or Tmpg DVD creator on most standalone dvd players. Some players don't accept, so I need to convert to 720*576 with a "FAST" transcoder.
    Usely a need 2 hours for trancoding a 1 hour stream on my XP 3000+.
    Do you know something really faster ? (with good quality !)
    Thanks !
    The "fast" setting in TMPGEnc should not affect the final outcome of the video much and will go like hell on a box that fast! Mine does it in just under real time. About 45 min per hour.
    Cheers
    Mainconcept is much faster than Tmpgenc.
  4. Originally Posted by Jraf
    Two options:
    (1) Go for mencoder.
    It's the fastest (but tedious) encoder available, but beware that it's very buggy when used on lower resolutions than your target.
    If your target is DVD, then you'll be fine.
    http://www.mplayerhq.hu
    (2) Create your VOBs with any authoring program, then use DVDShrink to transcode and make new VOBs.
    This should your best (fastest) option.
    Greetings,
    Baf
    - Snake Lover! -
    You can't change the resolution with dvdshrink.
    Cinema craft encoder or mainconcept encoder are my suggestions.
    Ronny
  6. The Old One SatStorm's Avatar
    I moved that to the correct forum (Digital TV).
    First of all, you can't transcode, you have to re-encode your mpeg 2 to another mpeg 2 with a compatible DVD Video resolution.
    I do that years now, but the opposite way: I don't convert to 704/720 x 576, but to 352 x 576.
    When someone re-encodes 544/528/480 to 352 x 576 can do a choice: Filter the DVB transmission, or re-encode it direct?
    Most DVB transmissions look "good" to "Excellent", but technically speaking, they have noise. And the bad thing is that is not a noise we can really "see". It is noise that the encoder do see. That has one huge (for me...) side effect: You need to rise the bitrate, so to keep the picture quality, at about the same shape.
    Personally, for those kind of convertions, I use dvd2avi to frameserve to TMPGenc plus encoder any DVB mpeg 2 source. Using CQ (because 2 pass VBR don't handle well IMO that unoticable noise I'm talking about, so the results after the convertion have noticable pixeleration...), I'm capable to encode one hour of video in about one and a half hour that way. Also, you don't need to re-encode the audio: DVD2Avi seperates the audio to .mpa.
    BUT: Since most DVB transmissions ain't clean and because I don't like the fact that I have to rise the bitrate for better results, I actually filter my DVB sources. I do minnor filtering (low portions of Static Noise Reduction / Dynamic Noise Reduction / Sharpen), and also I resize before TMPGenc (so not to have pixelerations and other issues to fade ins / outs). That way I also end up with smaller filesizes after my encodings.
    With filtering, it take me the same time as to encode my DVB source to full PAL. One hour for two that is.
  1. dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
    By aljolson in forum Newbie / General discussions
    Last Post: 8th Jun 2008, 11:54
  2. 1440x1080 to PAL SD 720 576 16:9?
    By katapulse in forum Mac
    Last Post: 20th May 2008, 04:44
  3. 720/576 on 1 CD-R
    By SirG in forum Newbie / General discussions
    Last Post: 5th Nov 2002, 11:00
  4. Convert 704*576 to 480*576 -> squeezed image
    By PSN2106 in forum Video Conversion
    Last Post: 3rd Oct 2002, 10:00
  5. Conversions DV-AVI PAL 720*576 to DV-AVI 480*576
    By Ernie in forum Video Conversion
    Last Post: 29th Apr 2002, 08:15
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
