I currently have the Magnavox MDV 455. I seems fine for dvd's and mp3 cds. I would like to play mp3 dvds (data disks). Is the Phillips 642 capable of this? I have read that it does not support shuffle mode in any format: is this the case? How would you compare these two models for regular dvd video playback?
I guess my final question is whether it is really worth the bother to have a xvid player, if I do not plan (can't - dialup!) to download any avi movies? I tried making a backup using fairuse and the output looked great on the monitor. But it took nearly 4 hours to encode. So I suppose the only advatage to xvid is the lower cost of cdr's? The disadvantage being encoding time and loss of menus.
Thread: Philips DVP 642 and DVD mp3
Another question: It seems this model has only been out for 3 months. Anybody had one just quit working? It it reliable? I had an Apex that stopped after 6 months. I have had the Magnavox for about 5 months and so far so good.
Thanks in advance for answering all these questions.
Yep,The Philips 642/17 Is a good Player.Go here for all the specs and downloads.
http://www.p4c.philips.com/files/d/d...17_pss_aen.pdf
If you d buy the 642,make sure you DL the Rom upgrade file & instructions.This will enhance the Divx playback.
I also have the Magnavox 458/17 player.It it almost the same at the Phil 642,without the Divx.
Philips owns(makes) Magnavox so they are fairly equal in quality.
I got the 642 at Target for $70,and the Mag at Circuit City for $50.
The 642 is in demand ,so it's hard to find.
\redline
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
