guys im dealing with VRO files of DVD Ram discs which i gathered are some form of mpeg2..
im confused myself..but im using tmpgenc plus, and i just wanna convert the VRO files to something more standardised..like an mpeg2 file..
but at super high quality? if u get what i mean. like i know if i converted them to mpeg1..id lost some quality..
so far, im converting them through the wizard as follows;
i choose DVD-PAL with MPEG1 LAYER II AUDIO(MP2)
I leave the 'expert settings for source' alone.. should i be changing them?
in 'other settings' - i change the rate control mode to '2 PASS VBR'
and often muddle with the audio increasing its bitrate to 384kb/s..
As u can see, i have no clue what im doing, just going along what i read in a guide though it wasnt specifically refering to the conversion of VRO files..
though a 3 gig VRO files takes about 2 hours with this process,theres a pretty good result. however is this the optimum quality root or should i be converting to Divx or something else..
thanks in advance
Nick
Thread: Best conversion for VRO files
Do you want to put them on a DVD-R? If so give TMPGEnc DVD Author a bash, it accepts VRO files.
no i dont..i just want to store them on my pc and be able to view them at optimum quality..
no recording at atall..
If you are able to extract the .VRO files from the DVD-RAM and save them to your hard drive, all you have to do is re-name them with the .MPG extension.
.VRO video files are MPEG2 already. You do not have to re-encode them.
VRO Files
By bz186 in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 3rd May 2010, 10:11 -
VRO conversion problems
By stellabelch in forum Video ConversionReplies: 3Last Post: 14th Oct 2009, 06:22 -
Extracting .VRO files???
By jbrdbr111x in forum Video ConversionReplies: 12Last Post: 24th Jun 2009, 20:34 -
Vro to Vob conversion?
By marty mcfly in forum Video ConversionReplies: 6Last Post: 30th Oct 2008, 21:16 -
VRO files
By tvlreject in forum Newbie / General discussionsReplies: 14Last Post: 8th May 2007, 13:31
