Any suggestion?
Now I use following method:
1) use Ulead video editor. Input the sound file, MP2, to editline.
2) shift the sound file behind some seconds such as 0.5s
3) save edited audio file in mpeg format (tag name .mpa)
4) combine the file by TmpegEnc Plus 2.5's tools (video: original mpg file, audio: above mpa file)
5) the correction is completed.
However, I worry whether any loss when I make the audio file in step (3).
Anyway, I can't feel any loss when I listen to the final file.
I doubt there will be any quality loss.
This plan is so bad, it must be one of ours.
Any suggestion for lossless method? Thank you.Originally Posted by Darth Paris
Create a MP2 file of 0.5 seconds and merge with the existing file.
No loss.
TMPGEnc will take source video that has no audio track and fill with silence if its told to. Open any AVI in VirtualDub, and disable the audio. Then set source range to 0.5 seconds and save as Direct Stream Copy.
Take the 0.5 seconds of video (with no audio) and open in TMPGEnc, load the same template you used before then encode. (You might need to load the "Unlock" template in order to select Elemental stream MP2)
TMPGEnc will encode 0.5 seconds of nothing to a MP2 file.
Then just use TMPGEnc's MPEG tools to merge the two files.
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 04:26 -
Add silence to beginning of track
By CSULB71 in forum AudioReplies: 3Last Post: 10th May 2010, 16:04 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 05:32 -
Vodai MP2 codec
By ljs3 in forum ffmpegX general discussionReplies: 1Last Post: 9th Jun 2007, 02:38
