VideoHelp.com Forum
Results 1 to 10 of 10
    Hi,
    Would a VHS/DVD combo or DVD Recorder allow "custom" settings enabling increased length VHS tapes, (6-8hrs), to fit on a single DVD, or are there standard settings that keep the time limit to 4hrs.-?
    Thanx!
    John
  2. Member lenti_75's Avatar
    if you go above 4 hrs on the dvd, the quality is really bad, even for a vhs source.
  3. I have the panasonic E60 - it supports up to 6 hours as a standard setting, and supports flexible recording times, not sure the maximum time limit. The results at 6 hours will probably be pretty poor though. You probably have to run a test and see if it is acceptable for your purposes.
    E
  4. Member Marvingj's Avatar
    Why would you want to ruin your DVD with 4 To 6 Hrs. of Vhs. Trash in & Trash out.
  5. e55 does 8 hours per disk. I wonder how that looks?
  6. The bitrate on 6hrs is lower than I make vcds at, a good tape will work at 4hrs. crummy tape, take it down to 2hrs,a really bad tape doens't record at all. at least on a Philips DVDR-75,
    Let me clarify:
    I am not that interested in improving upon quality of the source VHS; I can do that via my PC with my capture card, frameserving/filters and encoding software. If there is room for improvement via standalone units (ie: TBC, etc.), it would be an added benefit.
    I am interested in the SAME quality as the original VHS and especially fitting the same length of these VHS tapes (6-8hrs. EP), on a single DVD as a mere .mpg1 or .avi.
    Questions:
    1. Can I record from a VHS with either a VHS/DVD recorder or standalone DVD Recorder from VHS to DVD?
    2. If yes, than can I actually record 6-8hrs. EP VHS to fit on a single DVD?
    3. If so, what VHS/DVD Combos or DVD Recorders are recommended and proven to have done this?
    Thanx for all of your input!
    John
    I have tested out many, many recorders. The LiteOn 5001 in my hands right now, on this hacked firmware 1163, is seeminlgy doing an ADAPTIVE deinterlace on the 352x240 6-hour mode. That's nice. It's not drop-frame like others (even the JVC is drop). I'm finding acceptable quality on it, for those things that do not need best scenario encoding. It is also very block-free.
    Your mileage may vary.
    I'm still testing, no final conclusions yet.
    Thanx PapaSmurf,
    I'd be interested in hearing your results as to fitting 6+ hrs. of VHS on a DVD at this resolution.
    Thanx again!
    I was also wondering if VHS/DVD Combos have "6 hr." modes?
    I assume with this specific Lie-On model, one would have to hookup a VCR via RCA Cables, etc. in order for it to record from VHS?
    Thanx,
    John
  1. vhs cassette not sitting down one side in vhs recorder ?
    By oldfellow in forum Newbie / General discussions
    Last Post: 12th Mar 2012, 15:23
  2. Best VHS/DVD recorder?
    By Michael 77 in forum Newbie / General discussions
    Last Post: 10th Jun 2011, 17:59
  3. Replies: 4
    Last Post: 17th Nov 2009, 15:11
  4. Jaggies on VHS Transfers
    By zenzen1 in forum Video Conversion
    Last Post: 15th Apr 2009, 16:49
  5. That flicker again on my DVD-R transfers!
    By ministry88 in forum Restoration
    Last Post: 13th Apr 2009, 14:34
