hi,
i'm trying to do this with an avi produced by ffmpegx and a second soundtrack in mp3 (same settings as the soundtrack in the avi-file - VIDEO: mpeg4, 528x224, 25.00 fps. AUDIO: mp3, 48000 Hz, stereo, 128 kb/s) but nothing happens. ffmpeg is running for more than 30 minutes and no file appears, also there is no info in the process information window.
PID COMMAND %CPU TIME
954 ffmpeg 34.9% 33:27.99
is this normal? if yes how much time is approx. needed to do this?
ffmpegX 0.0.9L
thanks a lot!
Thread: muxing AVI + 2nd audio
Yes, it is normal that it can take some time.
i tried again, waited for nearly 90 minutes and then aborted the process. i try now with avi + ac3 file to see if something will happen.Originally Posted by major
cheers
The process can even take 1 hour with a slow machine.
okay, i found some time and muxed the avi and the existing mp3 file again. the process finished successfully after nearly 4 hours...Originally Posted by major
avi.NET sound problem in Interleaving AUDIO with VIDEO muxing
By ntiki in forum Video ConversionReplies: 4Last Post: 13th Mar 2010, 16:34 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
[AVI] Muxing aditional audio
By Wacken88 in forum LinuxReplies: 0Last Post: 25th Jun 2009, 09:56 -
h.264/AAC audio to AVI/MP3 muxing help
By Ryutso in forum Video ConversionReplies: 14Last Post: 8th Mar 2009, 12:13 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
