do i need to convert the bin or is there a process in which i must follow.
please help!!
IIRC, Nero can burn bin/cue. Just go to the file menu, select Open, and select the cue. Nero will write it just like it writes its native image format (.nrg)
/Mats
when i go to thew file open the cue and the movies is not there
If you want to see the files inside the image, you can mount the image with Daemon tools.
Bin/cue files are meant to be burned with cdr,not dvdr.
Ben Johnson-I didnt take any stereos!
What do you mean "movies is not there"? Have you burned it?
If yes: What's on the CD/DVD you've burned?
If no : You won't see any movie until you've burned the cue/bin (or mounted it as a virtual CD/DVD with Daemon Tools)
...or do you mean "I can't see and select the cue file when I select "File -> Open..." in Nero? If so, did you change the File Format select as in the picture? (or simply use file format "All Files (*.*)")
/Mats
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
