I have a Sony tvr-68 and I desperately want to convert to dvd. What methods/hardware do I need?
Thank you.
Ashley
You have two options.
Buy a new Digital8 camcorder since just about all models can play back 8mm and Hi8 tapes and convert to DV video. You hook the cam up to your computer and play back the tape and record the DV video signal to your computer using FIREWIRE (aka IEEE 1394 aka i.link).
The next BEST option is to buy the Canopus ADVC-100
This is an external box that hooks up to the computer via FIREWIRE (aka IEEE 1394 aka i.link). It has analog video (composite and S-Video) inputs and stereo audio inputs. You hook the output of your Hi8 cam to it (or any analog source such as a VCR etc.) and the Canopus ADVC-100 will convert to DV video and send it to the computer.
Either way you end up with a DV AVI file on your computer.
That is what you want both in terms of quality and ease of editing.
Get a Panasonic e55 dvd recorder, does it all automatically for you.
Note that NOT ALL Digital8 camcorders play back analogue 8/Hi8 tapes. In at least the last two latest lines Sony makes (DCRTRVx5x and DCRTRVx6x) ONLY the highest end models do this. For example, while the DCRTRV350 DOES play back analogue 8/Hi8 tapes (and simultaneously outputs DV data through FireWire while at it), the DCRTRV250 and DCRTRV147/150 DO NOT.
M: Bond, I want you back.
James Bond: I never left.
Can you elaborate? Will my hi8 trv-68 plug directly into this?Originally Posted by handyguy
Yes, he's referring to a set top DVD recorder which operates like a VCR. Plug your camcorder in with the audio and video cables and then record away. It's probably the fastest and easiest method, and the results are usually pretty good. Quality will vary depending on the brand, and some are higher rated than others. If you want to edit the footage then you can take the DVD that you produce and copy it to your PC. After editing you can reburn to DVD, if your PC has a DVD burner.Originally Posted by AshleyQuick"Art is making something out of nothing and selling it." - Frank Zappa
Please note that if you record your camcorder footage to a stand alone DVD recorder you will be recording direct to MPEG-2 format.
Although you CAN edit this after importing the DVD to your computer it is VERY important to note that MPEG-2 can be tricky to edit.
Many people like to do EXTENSIVE edting of camcorder footage including re-arranging shots and adding transitions etc.
MPEG-2 is not very well suited for this.
So I don't suggest going straight to MPEG-2 unless you do not need EXTENSIVE editing.
Hi8 camcorder with S-Video output?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 28Last Post: 24th Nov 2010, 12:12 -
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 16:39 -
Can I transfer CCD V5000 Hi8 Analog Video to digital on my Macbook to edit?
By thebird in forum EditingReplies: 2Last Post: 25th Apr 2009, 10:06 -
How to tell whether analog->DV video was originally Hi8 or Video8?
By Colmino in forum Camcorders (DV/HDV/AVCHD)Replies: 6Last Post: 2nd Jun 2008, 20:06 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
