VideoHelp.com Forum
Results 1 to 29 of 29
  1. Wten using it, it does this "flashy" thing..
    -OK, i put in the vcd (burned fine, tested on computer and dreamcast)when i put in the vcd in the apex ad600a dvd player it loads, and the timer starts, after that the movie kinda "jumps" or "flashes"...it's like watching a broken film strip..does anyone know whats wrong? does my APEX not able to play vcd's?
  2. Just a shot in the dark..have you tried turning PBC on or off?
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Come again??Whats this PBC thing??how do i turn it on or off??using my dvd remote?
  4. I have noted similar problems with my Hiteker DVD which I understand is the same player sold in New Zealand and Australia. However my problems were more with SVCDs than VCDs. With those turning PBC off with the remote then enables me to play the disk. Also noted recently problems very similar to those described that were cleared up after I put a CD cleaner disk (with brush) which seemed to fix the tracking problem.
  5. There's a button on your remote. It says PBC. Try hitting the button and then pressing play on the remote. I notice I have to do this with newgroup releases. Oh yeah, PBC=Play Back Control...I believe.
  6. I cannot find PBC button on my remote!!Where is it??could it be a picture logo?or be abbreviation??like i see a PS/LB word on the remote
  7. Ok, I got this PBC thing settled..it was currently on and didn't work...i will try turning it off, i should ask now, if it still doesn't work...what is wrong?
  8. try to switch from NTSC to PAL or from PAL to NTSC.
    Good luck!
  9. PBC on/off, does not work either way, and that nerd-out site
    do i post in the message board?or is there a faq that can tell me how to play vcd's?
  10. Ok, I can finally watch the movie!!!BUT....it lags..like if doctor grant says "Lets get out of here!!!" it would go "le get ou o he....re" so if the picture lags, the speech lags with it...but my other VCD worked, did i burn wrong??when i burn do i check "simulate"? help" i check finalize cd, disc-at-once and "write", should i check "simulation" this time??i don't want to waste a disc..i have very few left.
  11. i have the same Apex player. when that problem happened with me i had to lower the bitrate for encodeing. this cleared it up for me. i now encode video at 480x480, cbr-1700, and audio is 128 stereo. if i go any higher it won't play correctly. what speed are you burning? i read that a lower burning speed is better but i can't confirm that.
  12. Do not burn any VCD over 8x, CD-R burners burn a different way at 10x and higher, I have seen problems when I or others burn them at a higher burn rate than 8x, also I have the APEX 660 and the 600 and I play VCD at 2520 all the time perfect and SVCD at 2520 also with no problems, if I burn at 8x with my HP burner.
    There are two types of ways to burn, CLV and CAV one way(which I just can't remember) is for 8x and slower the other is for 10x and faster. I have even burned a VCD at 2800 and it played on the APEX 600, at 3000 it skipped sometimes and at 3500 choked completely.
  13. ALucard2050, how do i change those??i press setup, than where do i go in the menu???and thxkid, i burn at 4x and under
  14. i got apex ad600a nd i use vcdeasy for creating my vcd.choose vcd 2.0 turn on pbc nd burn it by 8x.if u got a 10x or higher writer just make a simulate(in options choose "bin/cue&quotuncheck delete cd image press go then burn it by using cdrwin(goldenhawk)load your cuesheet then choose ur burning speed to 8x.i havent encountered a problem yet nd my vcd's works fine
  15. what does simulate do on nero?
  16. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    How do i do that???in nero??berfore i burn??or in the menu of The APEX dvd??and what does simulate do!
  17. Hello,
    Don't know whether it helps but I do have an (firmware upgraded) Apex 600 and it plays SVCDs fine in all bitrate. Only when the rate gets over 2500 I get skipping problems. But 2100 is what I do for standard and gives perfect results.
  18. Sorry, I'm no expert when it comes to DVD machines, what's this firmware thing? And how do you upgrade it?
    And this rate thing, how do you adjust it or view it? is it in the menu/setup screen?
    _________________
    <font size=-1>[ This Message was edited by: XNeo_Mp3erX on 2001-11-16 18:16:36 ]</font>
  19. XNeo_Mp3erX, those settings i mentioned are all done when you encode. you do encode your vids don't you? or do you get them from someone else? the burning speed is done when you burn the file. how are you makeing your vcd's? i am able to view my vcd's with the pbc on. so i don't know if thats the factor or not. firmware is a program that is read by your dvd player directly from a cdr. it upgrades some of the settings in your dvd player, i think. i havn't done mine. i guess thats why i can't play svcd's very well. i could be wrong but the wrong firmware for your dvd player can be a bad thing causing your player to not function properly and is irreversable, but don't quote me on that. i am not overly noledgable on firmware.....another reason i havn't upgraded.....
  20. i don't know how to encode! Could you teach me?
  21. yo neo dude I am only 12 and I make vcd svcd xvcd and I sell them to friends at school!
  22. XNeo_Mp3erX, in the begining you say it burned fine. what are you burning? what is your process from begining to end on how you make your vcd's? i ask because you don't know what encoding is. are you just takeing an mpeg that you downloaded or captured and burning it to a cdr? these things i need to know in order to help.........
  23. Ok, i have the MPG file..i open nero burning rom
    > v.5.5.5.1
    > -I click "file", than scrolled down to "NEW"
    > -On the CD Compilatiom window i click the "videoCD"
    > icon on the left(the icon with the film strip and a
    > disc)
    > -I click "NEW"
    > -A "Nero burning rom video 1" screen pops up(the
    > screen you drag and drop)
    > -i find my movie on the right and drag it to the
    > "track/title" box on the left
    > -after the trasfer is done loading, i go "FILE" and
    > click on "WriteCD"
    > -Now the "writecd" window comes and i put write speed
    > at 4x (my max,slow eh?) ..write method i put on
    > track-at-once..number of copies i put 1
    > and above those it says "action" everything is
    > unchecked so i leave only "WRITE" checked..so
    > determine max speed, simulation, and finalize cd are
    > all unchecked..so with only "write" checked..i click
    > the "write" tab on the upper right and thats how i do
    > it...is something wrong that i did???HELP!!!!
    > RESPOND ASAP!
    thats all i do to burn vcd's
  24. how are you obtaining your Mpeg file? capturing, downloading, ripping?
  25. download in .mpeg form from morpheus
  26. what is the quality of the downloaded Mpeg. after you download it you should encode it and make the Mpeg file vcd compatable. just remember if the file before you encode is crappy then encoding will not improve the quality. that question gets asked alot here. for encodeing look under the HOW TO section to the left under CONVERT. that will explain how to take your files and encode them. it appears to me that your burning is correct you just need to encode it for vcd. my preference of encoder is TMPGE. its free and probably one of the best. i can only express the importance of reading alot of the info.
  27. wait so i encode using nero??or that program of yours?
  28. you encode with TMPGE and burn with NERO. TMPGE is in the TOOLS section to the left..after you get it look in the HOW TO section in CONVERT. It will tell you how to encode vid's. Just look for the one that says how to convert to VCD with TMPGE................
  1. Replies: 1
    Last Post: 13th Oct 2010, 01:00
  2. Apex DVD player AD-1100W - remotes compatibility
    By Matthias in forum DVD & Blu-ray Players
    Last Post: 2nd Dec 2008, 13:16
  3. Replacement for Apex AD-1500
    By siskiou in forum DVD & Blu-ray Players
    Last Post: 30th Mar 2008, 22:59
  4. Apex AD1250X Owners?
    By nemesys23 in forum Newbie / General discussions
    Last Post: 1st Jan 2008, 17:36
  5. Help! Apex 5131 Will Not Play DVD
    By NautTboy in forum DVD & Blu-ray Players
    Last Post: 24th Dec 2007, 11:33
