VideoHelp.com Forum
  1. how to display the subtitle automatically when beginning the movie?
    i have read this thread and done through the guide,but it doesn't work!!!i still have to click the DVDplayer menu to display the subtitle(do manually)
    here is the thread:
    This is only necessary if you want the subtitles to be displayed right at the beginning of the movie.
    As we didn't copied the DVD's menus, I think this is quite convenient.
    A little bit below the subtitles colors, you'll see "There is no PGC Command Table".
    Then right click on that to display the context menu.
    Choose "Add PreCommand".
    Now you have a small PGC Command Table which ends with "1.Pre Command NOP".
    Right click on "1.Pre Command NOP" and choose "Edit command".
    In the list, change "NOP" to "(SetSTN) Set Subpicture Stream Nr"
    Steam = 0, On/off = On
    Click on "ok"
    Save again.
    Quit
    thanks!any reply will be appreciated!
  2. Member Roderz's Avatar
    only done it in dvdlab but works - check out link in sig....
    I use.
    SetSTN(subp=0:on)
  1. Replies: 1
    Last Post: 19th Jan 2012, 07:36
  2. Do not display changed subtitle.
    By manjularoshan in forum Subtitle
    Last Post: 8th May 2010, 04:35
  3. Subtitle display
    By cheerful in forum Software Playing
    Last Post: 18th Jan 2010, 20:40
  4. Forcing specific subtitle to play automatically
    By eon_designs in forum DVD Ripping
    Last Post: 1st Dec 2009, 10:08
  5. Automatically creating pngs for DVDAuthor Subtitle MPGs
    By tacman1123 in forum Authoring (DVD)
    Last Post: 5th Jun 2008, 09:15
