VideoHelp.com Forum
    I generally capture TV streams via my DV Cam via the firewire interface on my PC and Pinnacle Studio. Works well but I have to be present to do the capture.
    I see various software packages (e.g Snapstream Beyonf TV) that give PVR functionality with analog TV capture cards. Is there any way or software that that I can use to give me this same PVR functionality via my firewire setup ? I generally want to be able to set the PC to record at a certain time.....
    Chris
  2. Member flaninacupboard's Avatar
    back in 01 i was using some software called showshifter. they were discussing adding DV support at that time, it's worth checking it out.
    let me know how you get on because i keep reccomending showshifter!
    I've been using Iuvcr and capping PICvideo mjpeg from my JVC HR-DVS3U via firewire... The only catch is that I have to set the channel on the deck since firewire connections don't allow for channel selection (at least in my experience)
    It's no big deal though... I just set the channel and set the timer in iuvcr and vola!
  1. Capturing SD 4:3 Movies with HD PVR
    By turbines in forum DVB / HDTV
    Last Post: 23rd Apr 2010, 07:46
  2. Any OTHER S/W for Capturing a DH-PVR?
    By Randall_C in forum Capturing
    Last Post: 22nd Oct 2009, 12:55
  3. Motorola DCT6214 PVR to DVD-R via firewire
    By kenmo in forum DVD & Blu-ray Recorders
    Last Post: 2nd Jun 2009, 12:04
  4. PVR HD to PC using FireWire ?
    By wingfan in forum DVB / HDTV
    Last Post: 6th Oct 2008, 11:51
  5. Replies: 10
    Last Post: 5th Mar 2008, 02:19
