Hello,
I'm going to record my own commentary track to an old tape. I'll record it to mpeg 2 and then record a sound file seperately (I know I need to convert it to mp2 or mpa for dvd compliance).
My question is which program lets you add a second audio track and select it like a professional dvd? I saw a post here on how to do it with ifoedit but I'd like to produce it once (you know, mix it with the mpg file instead of make the dvd layout then add the sound file).
If there is an easy way to add the sound file as a second audio track I'd be interested in knowing, thanks.
Kevin
yoda 313,
Ulead DVd Movie Factory 3 allows you to add a commentary over an existing video & audio file (without replacing the original audio). It lets you adjust the audio level of the two audio files (i.e. original audio & commentary).
I don't know of any way to select between different audio sources though (i.e. with or without commentary).
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
Hello,
Thanks for the suggestion. I have the Ulead SE 1 that came with my Wintv PVR250 card. I'll look into the newer program.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Add audio-track to DVD WITHOUT re-authoring
By vk_dk in forum DVD RippingReplies: 1Last Post: 14th May 2010, 19:57 -
I want to add an audio track to a DVD.
By Nagashi in forum Authoring (DVD)Replies: 7Last Post: 14th Apr 2010, 20:39 -
I want to add an audio track to an existing DVD
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 31st Jan 2010, 16:21 -
Can you add a second language audio track on DVD workshop 2
By uncle mikie in forum AudioReplies: 1Last Post: 14th Jan 2010, 23:22 -
How To Add Reverb to the Audio Track of a DVD
By arcelton in forum AudioReplies: 10Last Post: 10th Oct 2009, 06:29
Statistics
Newest guides
Latest tool updates
New media comments
