VideoHelp.com Forum
  1. I'm trying to save on file size by capturing at 320x480 (1/2 width frames). is there a way to specify the setting of a 2:1 pixel aspect ratio in the .prx profile itself? I know that you can specify it in the windows media encoder program, but i'm trying to get this profile to work with another software that uses windows media profiles.
  2. Member underwurlde's Avatar
    Interesting...
    What exactly are you trying to do with the resulting movie file.... just play it on a PC or eventually burn it onto a DVD?
    The reason I ask is if you are just playing it back on a PC, I would just ignore anything relating to PAR / DAR! The bit you need to know you already have, i.e. convert / encode / copy etc using 320x480.
    If you then play it back in windows media player, sure it will be squished, but hey who uses that! Use something proper like ZoomPlayer or DivX Player where you can set the playback aspect ratio!
    Aspect ratios got me in a hole once and the program which caused me infinite confusion was Media Player! Like I said, the upshot was to basically ignore aspect ratios.....
    I guess i'm not helping much but you never know!
    Regards,
    Andy.
    Work you bloody thing....
  3. that could possibly work... this is involved in a project that will be capturing video and converting in real time, and the resulting videos will be burned to cd and viewed at other computers. I can't say much more than that. But suffice it to say, most of the clients will only have (and know how to work) windows media player. I don't think using an add-on player will be the solution that we're looking for (but i didn't think of other players that could play with the PAR like that )
  4. Member underwurlde's Avatar
    OK, fair enough!
    So you have an original that is 320x480 that you want played back with an AR of 1.33:1 (If you use this AR, will also suit DVD authouring...)
    I guess that you are starting with an MPEG1 / MPEG2 and want to keep it so...
    I would therefore recompress (using VirtualDub MPEG v1.5.10) your half width source to one of the following H/V pixel sizes...
    640x480 = does not loose any of the original data but may end up bigger
    512x384
    448x336
    384x288
    320x240 = probably best but will loose half the vertical quality. Smallest
    Windows Media player will then play back with the correct (initial) AR of 1.33:1. Experiment with the above for best results...
    While in the resizing process, you could also try encoding using different compression codecs etc. in an attempt to reduce file size (if using alternate codecs is not a problem to your end users).
    I have found that Media Player picks up on the AR from the basic H/V pixel frame sizes. (I THINK!) I did look into the use of embedded DAR / PAR within the movie file header but did not get very far - it, as I have said, seems to be basically the pixel frame size but I would invite correction!
    Andy.
  1. conversion square to non square pixels???
    By jakeotr in forum Video Conversion
    Last Post: 27th Jan 2012, 00:53
  2. Square pixels or 16:9 Pixel aspect ratio?
    By Scherwin in forum Video Conversion
    Last Post: 18th May 2010, 12:47
  3. how do I convert a video that shows square pixels to no pixels?
    By sxpredman in forum Newbie / General discussions
    Last Post: 10th Jan 2010, 02:56
  4. Another question: Converting square pixels into round pixels.
    By Earthling2000 in forum Newbie / General discussions
    Last Post: 23rd Nov 2009, 10:20
  5. should use square pixels or not for 16:9?
    By j.man in forum Video Conversion
    Last Post: 4th Mar 2008, 21:28
