VideoHelp.com Forum
Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 62
  1. I wrote PgcEdit for me, but I finally decided to release it as GPL free software. So it's here.
    The main purpose of PgcEdit is to allow an easyer editing of the PGC commands than with IfoEdit... but I have added some functions that I find useful. Just try it to see.
    There is a short documentation (in english or french) along with the program, and on my homepage.
    Download PgcEdit here: http://home.tiscali.be/debie.roland/pgcedit/
    Have fun!
    r0lZ
    PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
  2. PgcEdit v0.2 is here.
    See the version history to see the changes: http://home.tiscali.be/debie.roland/pgcedit/HISTORY.txt
    r0lZ
    the history.txt says 0.1.3?
    Updated the pgcedit tool page to 0.2.0 anyway.
  4. PgcEdit v0.3.0 is released.
    The changes are mainly the addition of high level macros, for rookie users.
    And, of course, some other new features and enhancements. See the version history...
    Download PgcEdit here.
    r0lZ
  5. PgcEdit v0.3.1 is out.
    This version fixes an ennoying bug when trying to write the backup files on a read-only file system. No new features...
    r0lZ
  6. PgcEdit v 0.3.2 released.
    This is mainly a bugfix release, but there are some new functions and improvements, too. See the version history.
    Download PgcEdit v 0.3.2.
    r0lZ
  7. PgcEdit v 0.3.3 released.
    Main change is the ability to inspect the menu buttons commands (for Windows only, at least for now).
    Download
    r0lZ
  8. PgcEdit v0.3.4 released.
    Changes: version history
    The menu buttons information is now also available for Linux users. Also, there is now a wrapped, standalone version for Linux users.
    The homepage has changed, too. I have added some links, and there is now a GUI to be notified when the page changes (seems to be really SPAM proof.)
    I highly recommand to use this version: it is probably the most bugfree since the first version, thanks to beta tests from many users, specially 2COOL and $$$, at Doom9 forum.
    r0lZ
  9. PgcEdit v0.3.5 released!
    Change log:
    0.3.5 (October 4, 2004)
    A. The menu buttons informations are now available also for Mac OS X users.
    E. Blank Out all PGCs in Domain: added a confirmation dialog when overwriting the backup of the VOB file. Tooltips added for all options.
    E. The PGC selector may now be placed on any side of the main window. The PGC labels are now more legible.
    E. Tools configuration: Added argument substitution %n (Number of TitleSets)
    E. New option "Use file browser instead of folder browser for Open/Save folder operations?"
    F. Fixed a big bug with TTN number: was always the PGC number. The Title's entry PGC number were therefore also wrong. The TTN numbers are now correctly retrieved from the VTS_PTT_SRPT tables.
    F. Open DVD: It is now possible to open a DVD located in a directory even if a VIDEO_TS subdir exist in this directory. The VIDEO_TS directory is now automatically selected only if there is no VIDEO_TS.IFO in the parent.
    F. Set DVD-Text General Name: maximum string length bug hopefully fixed.
    F. The total time of a multi-angle PGC is now calculated for Angle 1 only.
    F. Command Editor CSetCLnk and CSetLnk bug fixed: When the IF 2nd operand is a value AND the IF checkbox is off, the Set's Value option was disabled.
    F. Missing file in the source archive added.
    Mac OSX users should refer to the homepage for installation instructions (Thanks to Damien).
    Also, on the homepage is a new HTML version of 2COOL's guide "How to Completely Blank Out a Titleset (VTS) Using PgcEdit", and a new "PgcEdit Anleitung" by Tobi. Thank you, folks!
    Homepage: http://home.tiscali.be/debie.roland/pgcedit/index.html
    r0lZ
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    http://home.tiscali.be/debie.roland/pgcedit/ doesn't seem to work...temporary problems or? if you need some webspace/webpage let me know.
  11. Yes, it was a temporary problem. Seems to be fixed now.
    Anyway, thanks for your proposition!
    r0lZ
  12. PgcEdit v0.3.6 released.
    Download
    Added:
    • Added the "PGCs params and Cell table" menu to dump all PGCs.
    • Added the "Remove Parental Managment" utility.
    • Thanks to jsoto, The VOB/Cell ID remapper (in the PGC Editor window, VOB/Cell ID buttons) has now the ability to append a new blank cell to the VOB. Handy to blank out a specific cell. Currently for Windows only.
    Enhancements:
    • Changed the "Info/PGC commands" to "Info/PGC". Now, dump also the PGC parameters and the Cell Table.
    • "Find Unused GPRMs" now search also for GPRMs in the menu button cmds.
    • In the disassembly of integer values, the ASCII equivalent of the value is now displayed only if it is a valid language code. (No more "..")
    • The first column of the Cell Table in the PGC Editor is now the Number of Buttons for a Menu PGC (and still the Chapter Number for a Title).
    • New popup menu on the Search fields of the main window and the text viewer, to clear, copy and paste in the search field.
    • The Copy and Cut buttons in the main window are now placing the command in the clipboard without the "{" and "}" characters if only one command is copied/cutted. Handy to paste the hex codes in the search field.
    • Command Editor: When pasting in the hexadecimal field, the command is now automatically validated, and transferred in the GUI.
    • The number of buttons shown in the PGC labels is now "?b." if the VOB file is missing or not readable. Was "0b." before.
    • Now, the "Cell Type Flags" editor doesn't allow to select an Angle Type if the Angle Block flag is not checked.
    • "Kill PGC Playback" changes now also all Link to Cell, PG or PTT pre commands to GOTOs (only if the Highlight Button parameter is not used.)
    • Documentation updated (and english doc corrected.)
    Bug fixes:
    • "Kill PGC Playback" will now remove the post commands after a Kill if the total number of commands exceeds the fatal limit of 128.
    • "Import First-Play Clip" and "Import Title's Intro Clip" bugs fixed.
    r0lZ
  13. PgcEdit v0.3.7 released.
    version history:
    • A. Blanking a cell (in VOB/Cell ID remapper) works now for all platforms.
    • A. It is now possible to enter an ASCII string (for example a language code) in any numeric field of the Command Editor by prefixing the string with ' (single quote character, aka apostrophe). Example: 'en = 25966
    • E. PGC Editor: GoUp (Return) value can now be Resume (0xFFFF) for a Menu PGC.
    • E. "Enable Navigation Buttons" has now an option to enable the GoUp (Return) button to resume to the Title domain from any non-dummy Menu PGC.
    • E. Calls Cross References: now display also the PrevPGC, NextPGC and GoUpPGC links, but do not display anymore the calls to the same PGC. The Unreferenced PGCs list is therefore more accurate.
    • E. Disassembly: New error messages:
      Set gprm(n) ?=(rnd) <ILLEGAL VALUE 0 FOR ?=(RND) OPERATOR>
      Set gprm(n) /=(div) <ILLEGAL VALUE 0 FOR /=(DIV) OPERATOR>
      Set gprm(n) %=(mod) <ILLEGAL VALUE 0 FOR %=(MOD) OPERATOR>
      (SetAMXMD) Set Karaoke Audio Mixing Mode =(mov) <ILLEGAL VALUE 1...>
      (SetGPRMMD) Set gprm(n) =(mov) <ILLEGAL SPRM OPERAND sprm(n)>
    • E. The value field of SetAMXMD is now replaced by 6 checkboxes in the GUI.
    • E. Selecting an item in the Command Editor menu "Numerically -> 40-D0: Set" now update the value/GPRM/SPRM radiobuttons automatically in the GUI.
    • F. As the SetGPRMMD source operand may not be a SPRM, the SPRM option has been removed from the Command Editor GUI.
    • F. 'Blank all PGCs in Domain' now correctly update the video, audio and subpic attributes in VMGM_MAT/VTSI_MAT/VMG_VTS_ATRT tables.
    • F. 'Blank all PGCs in Domain' (when blanking w/o kill playback): the video was sometimes unplayable. Now fixed (thanks to jsoto)
    • F. Command Editor: The maximum number of PGCs is now 32767. (Was 65535)
    • F. Set used with AND, OR, XOR or RND was unable to disable the LinkNoLink.
    • F. GOTOs in pasted lines with Paste Replace were renumbered in some cases.
    • F. New PGC: When creating a new PGC in the Title domain, the VTS_PGCI table is now correctly updated.
    • F. Target highlighting and "Jump To Target", when used in a multi-PGC title, were unable to find the target of JumpVTS_PTT and LinkPTT if the chapter was in another PGC belonging to the same Title.
    • F. Error launching PgcEdit when the TEMP directory is not writable trapped.
    • F. Error in the Uninstall procedure fixed.
    r0lZ
  14. PgcEdit 0.3.8 released
    • New Edit -> Append to Scratchbook function to add the selected commands directly to the scratchbook. This option is also available in the menu buttons viewer (with the clipboard functions.)
    • PGC Editor: added the ability to edit the PG Playback Mode (sequential, random or shuffle mode.)
    • It is now possible to paste commands in full text format (copied with 'Copy as Text') directly in the main listbox. Note that the *** labels are not pasted: you may therefore paste the pre, post and cell commands in one operation, but all commands will be pasted in the same section.
    • New option "Include [hex codes] in Info / commands dumps ?".
    • Help -> ISO639 Language Codes now lists also the decimal and hex values.
    • Since CSetCLnk, CSetLnk and SetCLnk must have an IF condition, the IF checkbox has been removed from the GUI.
    • Now, the "New 'Play All' Title" utility display the new TTN number in the PGC selector.
    • Undo now mark the DVD as modified.
    Also, there is now a new mirror of the PgcEdit's homepage at... www.videohelp.com! Thanks again, Baldrick!
    r0lZ
  15. PgcEdit 0.4.0 released
    • Trace mode!
    • PGC Editor: It is now possible to edit the Programs map by clicking on the Prog buttons.
    • PGC Editor: Added a Chapter (PTT) table editor.
    • In the menubuttons viewer, clicking on the Jump to Target button will now close the viewer (but only if the target is found, and is another PGC.)
    • SetSTN: Changed the labels for audio value 15 and subpic 62 from 'set to none' to 'not set', which IMHO is more coherent.
    • PGC Editor: New tooltips on the stream assignments buttons.
    • The stream numbers in the PGC selector were starting at 1 instead of 0.
    • The subpic stream assignment slider range was 0 to 15 instead of 0 to 31.
    • The VTS Sectors adjustment was wrong with empty (0 byte) menu VOBs.
    • Command Editor: Little bug fixed when a value field was empty and the "B" button was selected.
    About Trace mode
    The Trace mode is still in a somewhat experimental state.
    Known limitations:
    • No documentation. Sorry
    • Since the virtual playback is not in real time, the behavior of the NAV counter and of the GPRMs in counter mode cannot be simulated. SetNVTMR and SetGPRMMD (in counter mode) are therefore only partially supported.
    • There is no preview of the video (for now).
    • There are certainly still many bugs in the code. However, since the Trace mode do not modify anything in the current DVD, you may use it safely.
    Check out the Jeanl's Guides for PgcEdit for excellent examples of the usage of the Trace mode.
    Please note
    I have changed the distribution status of PgcEdit from freeware to donnationware.
    I have already spend months to develop PgcEdit. The new Trace mode was verry hard to do, and the other features I will add are also involving many time in develpoment. So, if you like and use PgcEdit, please donate!
    To make a donation, click on the PayPal button on my homepage. (Actually, there are 2 buttons, so you cannot miss them. )
    Many thanks in advance.
    r0lZ
  16. PgeEdit 0.4.1 released.
    • Limitted preview in the Menu Buttons viewer: the first frame with buttons is displayed. For Windows users only. Sorry.
    • The 3 Import Clip marcos now automatically allow to use the Mext Chapter button to skip to the end of the imported clip (or still frame).
    • Little cosmetics changes.
    • Fixed Save DVD bug after 'New dummy PGC' in Title domain.
    • Trace: LinkTopCell, LinkPrevCell and LinkNextCell bug: The jump was done to the cell following the real target cell.
    Thanks to the generous donators!
    @ the other: Don't forget to donate...
    r0lZ
  17. r0lZ,
    Can I use your software to make a set of DVD files random playable?
    I use Audio DVD Creator to put music on DVD's. I can encode at twice the bitrate of MP3 using AC3 and I have menus to select the album.
    The problem is that you can't random play the files. Its my understanding that its due to the PGC commands written in the files. I would like to edit it before I burn more.
    THX, JNT.
    For the love of God, use hub/core labels on your Recordable Discs!
  18. Certainly, you can.
    However, what you need to do depends on the way you have authored your DVD.
    For example, if all your audio files are concatenated in one PGC, with each track in a different program (aka chapter), all you have to do is to change the PG Playback Modes from sequential to random or shuffle (in the PGC Editor). If you want to keep the ability to play them in sequence, you will have to duplicate the PGC, and have a menu button to call the modified PGC as well.
    But if the audio tracks are authored as individual titles, you will need to change the DVD commands to pick the titles at random (shuffle mode will be verry difficult to do). This requires a good knowledge of the structure of a DVD, and some programming skills...
    Good luck!
    r0lZ
  19. Thanks for the reply
    Each Album is on its own Title, with each song on its own chapter. So I guess based on your email, I could change the PG Playback Modes from sequential to random or shuffle (in the PGC Editor). And during playback it will only play as random?
    But, what I don't know how to do is:
    1.) Duplicate the PGC.
    2.) Create a menu button to call the modified PGC.
    Tried contacting the vendor and no reply.
  20. You can duplicate the PGC with the 'New Play All title' macro in PgcEdit.
    This will make a new PGC containing all the chapters of all PGCs of the current VTS.
    However, PgcEdit is not suited to create a new menu button. You may try to use MenuEdit for that purpose. The free version will probably be suficient to create a new, hidden button that you will be able to selest, but not to see.
    If you want a better solution, you will need to author a new menu with an authoring program, and import it with PgcEdit. However, this is not verry easy to do.
    r0lZ
  21. PgcEdit v0.4.2 released.
    No new features, but it's an important bugfix.
    • The VTS_PTT_SRPTI table was not correctly rebuild when the DVD was saved for multi-PGCs titles.
    • Bug fixed in the menubuttons viewer when displaying a still frame menu with audio: the first frame of the next cell was shown. (Windows only)
    • Bug in Tcl/Tk libraries that occasionally crashed the menu button viewer (with image preview) hopefully fixed. (Probably Windows only)
    r0lZ
  22. PgcEdit 0.4.3 released.
    • Preview (Windows only) by Jeanl, based on Jsoto's modification of DVD2AVI.
    • Little refresh bug after edition of the PTT table in the PGC Editor fixed.
    • Little bug fixed in Tcl/Tk code, related to the position of popup menus.
    Some notes about the Preview:
    You should be grateful to jeanl, who did the exe I use to display the preview. This was a big work! It is based on Jsoto's modification of DVD2AVI, which was originally programmed by LOLI.J. Thanks jeanl, jsoto and loli!
    BTW, jeanl did also the exe used to display the background image in the menu buttons viewer. Thanks again, jeanl!
    If you don't like the preview window 'always on top', you should change this option in the little system menu of the preview window.
    There is still a problem when displaying a multi-angle cell: all angles are actually shown. But this may be considered as a feature, not a bug!
    The source code of both preview executables will be available soon.
    Also, there is now an unofficial mirror of the PgcEdit home in Poland, updated daily, thanks to RobertR, aka ideJ.
    [EDIT:] The URL of the mirror has changed.
    r0lZ
  23. PgcEdit 0.4.4 released.
    Additions:
    • PgcEditPreview version 1.3 (See bottom of this text for Preview history.)
    • Added Preview full Domain VOB(s) utility. (Windows only)
    • Menu buttons viewer: arrows to select the image to show in the background.
    • Trace: Added a checkbutton to enable or disable the automatic preview.
    • Trace: Added highlights of the played PGCs (and a menu to clear them in Trace/State, and a popup menu when clicking on a blank line in the PGC Selector).
    • Info/Calls Cross References highlights the unreferenced PGCs in pink.
    • Preview: The Info window of DVD2AVI strikes again. (Modified by Jeanl, now includes the number of buttons.)
    Enhancements:
    • Clicking or right-clicking on the current PGC line in the PGC selector do not change the current selected command in the main listbox anymore.
      Handy to use the PGC Selector popup menu, and continue the trace.
    • Kill Playback and Blank Out functions now reset the PGC Still Time to 0.
    • Commands Editor: CallSS command has now the Resume Cell 1 by default.
    • Trace watch Input: Reset button replaced by the usage count of the current GPRM or SPRM.
    • Trace: it is now possible to break the Run mode from within the Preview window. Thanks to Jeanl.
    • Added a Preview menu, and moved the preview actions and options menu items there.
    • dvd2bmp.exe is now integrated in PgcEditPreview.exe, and is not included in the Windows distribution anymore.
    • Menu buttons viewer: Middle-clicking or Control-Left-clicking on a menu button when not in Trace mode will now jump to the target of the button.
    Bug fixes:
    • Bug fixed in PTT_SRPTI table when the chapters are not in ascending order.
    • Trace: Bugs with Title without TTN assignments fixed.
    • Trace: RSM was jumping to the first cell instead of the last visited cell.
    • Fixed bugs when parsing the VOBs to find menu buttons when the VOB IDs were not sorted in ascending order, or when some VOB IDs were missing.
    • Bug when creating a new dummy PGC in title domain fixed.
    • Preview 1.2 and 1.3: optimisation and bug fixes. (by Jeanl)
    • Fixed problem with focus not returning to the main window after a Preview.
    • Trace watch Input: Language code and Button number are displayed only when the current GPRM or SPRM value is a legal language code or button number.
    • Some more small Tcl/Tk library bug fixes.
    r0lZ
  24. PgcEdit 0.4.5 released.
    • Added 'Remove Cell' button in the PGC editor.
    • Added "Clone PGC" function (works in Title and Menu domains)
    • PgcEditPreview version 1.4, by Jeanl.
    • Menu buttons viewer: It is now possible to hide the buttons by clicking on the background image. (Windows only)
    • Dummy PGCs in the title domain are now labelled with "(dummy)" instead of "(0:00)".
    • "New Dummy PGC" in title domain now create the dummy 'attached' to the current Title (ie, it inherit the current Title and TTN numbers.)
    • The Layer Break checkbox is now disabled in the Cells List of the PGC Editor when the Seamless flag must be kept OFF. Therefore, the checkbox is checked and enabled only for real layer breaks.
    • Renamed some labels of the Type Flags in the Cells list of the PGC Editor.
    • The Remapping VOB/Cell ID function in the Cells List now clears the Seamless Playback flags of the remapped cell and the following one.
    • The TTN numbers are now retrieved from the VTS_PGCITI table, instead of VTS_PTT_SRPT. This is more reliable.
    • Bug in "New 'Play All' PGC" function with wrong Category Mask and Parental ID Mask in the VTS_PGCITI table fixed.
    • Bug in VTS_PTT_SRPTI table when saving a DVD with illegal dummy titles.
    • Bug when launching both Preview and Menu buttons viewer at the same time fixed by Jeanl.
    PgcEditPreview 1.4 by jeanl (Windows only)
    • Improved error reporting in bitmap saving mode.
    • Fixed a bug that prevented preview from loading some VOB files in bitmap saving mode.
    • The elapsed time was wrong in some cases (SCR discontinuity), I'm setting it to 0 if the audio pack has no PTS.
    • Fixed a bug that caused an image to be displayed in the improved bitmap-saving version of preview.
    • Rolled in most changes made by jsoto for vobblanker.
    r0lZ
  25. PgcEdit v0.4.6 released.
    • Info -> Go To Calling Command function.
    • Menu Buttons Viewer now displays the video in the correct aspect ratio, and selects the buttons group matching the player setup in Trace mode.
    • Miscellaneous enhancements and little bug fixes in Menu Buttons viewer and Trace mode.
    • PGC Editor: The total number of buttons displayed in the PGC selector was wrong after the user accepted the modifs in the PGC Editor. Fixed.
    • New 'Play All' Title: Fixed the Next, Prev and GoUp PGCN of the new PGC.
    r0lZ
  26. PgcEdit 0.4.7 released.
    • New "Delete Last PGC in Domain" utility to remove the last PGC of the LUs in the current menu domain, or the last PGC of the current title domain. In title domain, the last PGC must be the last TTN of the titleset and the last Title in the DVD.
    • Added a check for incorrect number of VOB IDs in the VTS_C_ADT table as a workaround for a DVDShrink bug in reauthor mode (number of VOB IDs saved in the table is always 1).
    • As a SPRM cannot be used as the first operand of the IF comparison, the SPRM option has been removed from the GUI of the command ediror. Also, a command with a "if ( sprm(x) ... )" will now generate an ILLEGAL SPRM warning.
    • Show Menu Buttons did not work when there were no buttons in the first cell of the PGC.
    • PgcEdit Preview v 1.5: Fixed a rare problem where preview was displaying black frames instead of the video.
    r0lZ
  27. PgcEdit 0.4.8 released.
    • Option "When saving, leave at least 32K of space between IFO and BUP?" to help protect your DVD against defects and scratches. Use with caution!
    • Added File -> Burn DVD / Create ISO to create an ISO image with mkisofs and optionally burn it with DVD Decrypter. This method supports the 32K space option above. For Windows only.
    • When loading the DVD, a warning is issued if there are empty (0 byte) menu VOBs. Also, the stream attributes of the VOBs are resetted to 0 when the menu VOB is removed by the 'Blank Out All Menu PGCs' function.
    • Trace mode: Removed "WARNING: Trying to play cell 1 of a dummy PGC!" dialog when a dummy PGC is played. However, this message is still present if the cell to play is not cell 1.
    • Fixed rare a bug occuring in Trace mode when the First-Play PGC was played (ie. when the current position was on the "*** post-command" label)
    r0lZ
  28. PgcEdit 0.4.9 released.
    • Added the "DVDShrink Streams Remapping" macro to check if the DVDShrink option "Logical remapping of enabled streams" may be safely used in full disc mode with the current DVD.
    • Added a button "ISO639 language codes" in the Trace's Virtual Player Setup GUI to show the valid language codes.
    • The PGC breakpoints are now cleared when a new DVD is loaded, but still not when the same DVD is reloaded (including after a restore backup).
    • Burn DVD: Added an option to mount the ISO image using Daemon-Tools.
    • Burn DVD: Added a confirmation dialog if the ISO image already exists.
    • Burn DVD: The VobBlanker_backup folder is now automatically excluded of the ISO image, like the PgcEdit_backup folder.
    • Burn DVD: Miscellaneous enhancements and little bug fixes.
    • Burn DVD Bug fixed: The abort button did not kill the mkisofs process in the standalone exe.
    • Burn DVD: Free disk space was wrong on Win 9X and on foreign Win 2K/NT/XP.
      Note: The free disk space is not tested anymore on Win 95/98/ME/SE!
    • Shortcut to select all the Trace output changed to Control-Shift-A to avoid a bug with Control-a.
    Also, look at the homepage. There are updated and new guides...
    r0lZ
  29. PgcEdit 0.4.9.1 released.
    This is a last minute bugfix for 0.4.9. It fixes the bug in the DVDShrink Streams Remapping macro, found by Blutach.
    If you downloaded PgcEdit 0.4.9, please download the update now. Sorry for the inconvenience.
    r0lZ
  30. PgcEdit 0.5.0 released.
    • BOV (Buttons Over Video in Title domains) support:
      - Replaced the executable button_dump.exe by a Tcl/Tk function, able to parse the menu buttons in menu domains. The menu buttons informations are therefore available also for Macintosh pre-OSX platforms.
      - Added "File->Find BOVs" and "Options->Automatically Launch BOV finder when a DVD is opened?" to find the BOVs at startup.
      - "Utilities -> Show Menu Buttons or BOVs" works now also for Title PGCs.
      - Added "Show BOVs" popup menu in the PGC selector on title PGCs.
    • Removed the "Options/Show libdvdread warnings when parsing menu buttons?".
    • "Fix number of streams in VMGM/VTSI_MAT tables" macro to change the number of streams in the VMGM_MAT and VTSM_MAT tables according to the number of streams enabled in the PGCs.
    • Domain Streams Attributes check now if the current number of streams match the number of streams enabled in the PGCs.
    • Domain Streams Attributes allow now to edit the audio stream types and parameters. (Still no support to edit the karaoke parameters.)
    • Open DVD: If there are empty VOB files, an option to delete them is now presented to the user when the DVD is loaded.
    • Added a Burn DVD/Create ISO toolbar icon. (Windows only)
    • Added some missing credits and thanks in the About dialog.
    • Kill Playback macro: New algorithm to determine if it is safe to use the macro. It is safe to kill playback if there are no menu buttons, and if there are no cell commands jumping outside of the current PGC.
    • Blank Out PGCs in Domain: The "Kill Playback only when it's safe" option now uses the new Kill Playback macro.
    • Cell type flag SCR Discontinuity (System Clock Reference) renamed to STC Discontinuity (System Time Clock). (Recommandation of Mpucoder)
    • Burn DVD: The MenuShrinkBackup is now removed automatically from the DVD.
    • Added the audio and subpic stream IDs in Domain Streams Attributes GUI and in Info -> Streams.
    • PgcEdit_Preview.exe v1.6 by Jeanl. Fixes an aspect ratio bug with VCD and SVCD resolutions, and another one with garbage addeded in the bottom of the image when the vertical resolutions was not a multiple of 32.
    • When a cell is reassigned or blanked, the Seamless Joint flag is now cleared.
    • Trace mode: The target of LinkPTT commands was wrong (was pre-commands of the PGC instead of target chapter.)
    • Trace mode: A NOP command in a menu button or BOV is now ignored.
    • Highlight Target/Jump to Target did not work in some cases with CallSS.
    • Menu buttons viewer bug: After selecting another frame with the < and > buttons, the background image was not displayed for VMGM menus.
    • Fixed a bug with the Video Attributes display. The resolution, bitrates and 'top & bottom cropped' flags were wrong. The saved attributes were OK, though.
    • Fixed a bug when writing a PTT_SRPTI table containing PTTs assigned to program 0. Yes, I've seen a DVD with such bizarre things!
    • Fixed a bug occurnig after a Delete Program. The program map table was not padded to an even number of bytes.
    • Misc. little bug fixes.
    r0lZ
  1. Best Free Video Editor
    By Spiralagnus in forum Newbie / General discussions
    Last Post: 27th Jul 2011, 19:42
  2. Free video editor
    By jazzygirl in forum Video Conversion
    Last Post: 16th Jul 2011, 01:54
  3. Need free XP .mov editor
    By BayouBill in forum Newbie / General discussions
    Last Post: 26th Jul 2009, 08:22
  4. Free VOB Editor
    By acw in forum Newbie / General discussions
    Last Post: 5th May 2009, 18:12
  5. Replies: 1
    Last Post: 22nd Feb 2009, 02:25
