  1. Member LisaB's Avatar
    I burned an AVI to disc, only to find that it was not seekable in the standalone (Philips DVP642) DVD player....neither fast-forward nor "jump to" feature would work. I ran the AVI through DivFix (rebuild index), and now it will work fine in the standalone.
    The problem here is that there *were* no problems playing this AVI on the computer...so I had no way to *predict* whether it would be seekable on the standalone. This is frustrating. Is there any software out there that will check the index and let me know if I need to use DivFix? Is there any software player out there that will do a better job of imitating a standalone DVD player for testing purposes? Could it be that I have some kind of filter installed on my computer that is automatically "fixing" video streams? I'm just wondering why the AVI with an obviously bad index is playing and seekable on my PC...
  2. Check for keyframes (Virtualdub can do this) . I think you
    need 1 every 3 seconds but due to the differing mp4 chipsets and
    firmware - not to mention codecs - there is no guarantee
    that it will work in every mp4 enabled standalone. Most
    DVD players, of course, can't play avi at all.
  3. Member LisaB's Avatar
    No, that cannot be it. Divfix made this AVI seekable in the standalone. Divfix cannot create keyframes, only re-encoding could do that.
    There had to be something funky about index...it seemed to work okay on the PC but not the standalone...
  4. Divfix does not identify or fix AVI problems, it just makes
    a corrupt AVI playable by rebuilding the index and furthur it does not do
    as good a job as VirtualDub when doing this. Rebuilding the index
    often fixes keyframe issues, so I would not dismiss my suggestion
    as quiclky as that.
    1st you find the exact problem with your avi - then you have a lead
    in what might be the problem. With downloaded, network transfered files AVI damage is normal and it is just bad luck. When creating your own it is not.
  1. How to Make ( problematic or something) DVD Seekable?
    By devilcoelhodog in forum Authoring (DVD)
    Last Post: 18th Sep 2009, 20:55
  2. rewrap mov to avi with ffmpeg but audio not seekable
    By yannanlu in forum Video Conversion
    Last Post: 8th May 2009, 16:17
  3. mpeg videos not seekable
    By piktun in forum Software Playing
    Last Post: 19th Mar 2009, 08:55
  4. Making an MPEG\2 seekable?
    By Cobra281 in forum Video Conversion
    Last Post: 6th Nov 2005, 17:40
  5. Seekable ASF's
    By armando in forum Video Conversion
    Last Post: 7th Jul 2002, 23:19
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
