VideoHelp.com Forum
  1. I´m trying to backup this dvd, but the blue screen keeps showing everytime.
    I´read the doom's guides for the simpsons 3 season, and try decrypting with the settings that they said, except that in "when harry met sally" the region protection is on vts_07.ifo file.
    B.T.W. the dvd is region 4, and im using dvd decrypter and also trying to do something with anydvd, with no luck.
    any ideas?
    if you're in the USA or canada, the dvd has to be region 1. you can use dvd shrink to change the region to 1.
  3. Banned
    Uhh...
    0. Make sure AnyDVD is running.
    1. Insert disc.
    2. Drag files to hard drive.
    3. Burn files.
    Huzzah!
    Or better yet:
    1. Insert disc in reader, blank in writer.
    2. Hit "copy".
    Huzzah!
    I'm failing to see what the problem is here. In its default configuration, AnyDVD removes region coding and sets the region either to "none" or to your native region.
    What exactly is the issue?
    - Gurm
  1. HELP! Black screen/Blue Screen problem
    By will7370 in forum Computer
    Last Post: 1st Apr 2012, 09:30
  2. Again blue screen!!!
    By alintatoc in forum Computer
    Last Post: 10th Dec 2009, 14:16
  3. Blue screen?
    Last Post: 1st Nov 2009, 06:53
  4. what's a blue screen?
    By aruwin in forum Computer
    Last Post: 23rd Sep 2009, 08:56
  5. Blue Screen Of Death
    By Squid_uk in forum Computer
    Last Post: 31st Mar 2008, 14:35
