VideoHelp.com Forum
Results 1 to 11 of 11
  1. All of a sudden when I try to open the program I get the splash screen but then it goes away and nothing else comes on the screen?? Anyone seen this before or know what might cause this? It worked a few days ago fine.
  2. Nope, but i think a deinstall and reinstall we help you running the program again.
    Greatings,
    Yf
  3. Member ChrissyBoy's Avatar
    There may have been a change to your system. If you double click on the SVCD2DVD demo.exe file in the SVCD2DVD folder you can redo the registration process. This should solve the problem.
    Regards,
    Chris
  4. Mmm I had this last week, didnt matter what i done it wouldnt restart, i deinstalled and reinstalled in the end i had to reinstall windows.
    Didnt know about running the demo though
  5. Member ChrissyBoy's Avatar
    Its not the demo. There is a file called "svcd2dvd demo.exe" which resides in the svcd2dvd folder. If this doesn't resolve the issue, email me & we can work through it together.
  6. well i had to rebuild my computer anyway. but when i try to register it says expired, when i just purchased this like a month ago.
    can you please help me out.
    thanks.
  7. Member ChrissyBoy's Avatar
    can you email me your reg.xml file?
  8. Mine stopped working today, I uninstalled it then reinstalled - works fine now. No idea why it stopped working, but I had installed some new AV software (Sophos) and some java popup blocking apps (Google toolbar & Adsgone) - Still, all fixed now
    After a PC crash, tried to reinstall SVCD2DVD, I canīt. Program said that I have reached limit (3) registrations. Waiting for ChrissyBoy mail reply.
  10. Member ChrissyBoy's Avatar
    meupc: You should be ok now.
    Thanks for your help Chris, now working fine. :P
  1. Svcd2dvd stopped working
    By H4MST3R in forum SVCD2DVD & VOB2MPG
    Last Post: 12th Apr 2011, 21:53
  2. Replies: 3
    Last Post: 13th Jan 2011, 11:42
  3. SVCD2DVD Stopped Working
    By magic90 in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Sep 2010, 07:07
  4. Why have my TV speakers stopped working?
    By jimbo7777 in forum Audio
    Last Post: 17th Apr 2010, 18:19
  5. WMP stopped working?
    By glowworm12 in forum Computer
    Last Post: 22nd Feb 2008, 08:44
