VideoHelp.com Forum
Thread: new case...
  1. Member beavereater's Avatar
    When it comes to buying the main things(mobo, video card etc.), I kinda know what I am looking for. Now I want to buy a new case, because its just that time!! Anyway, what should I look for...anything cool out there?? Actually, the real reason for getting a better case, is for cooling purposes, and most of the cases here come with power supplies. I need a quiet one...anyone, any advice on a case would be cool...
    SmileSmile
    I like aluminum cases for the cooling abilities. Look for better quality fans with bearings to keep the noise down. Most materials that help reduce noise inside the case also insulate it making it less efficient at dissipating heat.
    Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress?
  3. Member Treebeard's Avatar
    Here is a case w/ a lot of fan room
    http://www.newegg.com/app/viewProduc...156-019&depa=0
    has room for 4 intake 80mm fans, 2 side 80mm fans and 1 60mm rear fan.
  4. contrarian rallynavvie's Avatar
    I got an Antec P160. It wasn't cheap but certainly not an expensive case. It's all aluminum and has plenty of features. It used 120mm case fans which I'd highly recommend as they're generally quieter than the 80mm fans.
    I also had a Lian Li which I liked a lot but they get pretty expensive. They just came out with a gorgeous new case that looks a lot like the G5 case.
    http://www.lian-li.com/products/pcv1000.htm
    Depends on how much you want to spend I guess. I would only go with an aluminum case using 120mm fans though.
  1. Big enough pc case?
    By A Traveller in forum Computer
    Last Post: 21st Aug 2011, 08:37
  2. Case Shortage!
    By videobread in forum Media
    Last Post: 10th Jan 2010, 11:22
  3. new computer case
    By minidv2dvd in forum Computer
    Last Post: 29th Sep 2009, 01:13
  4. External case - 3.5 or 5.25 case....
    By kenmo in forum Computer
    Last Post: 2nd Jan 2009, 15:54
