VideoHelp.com Forum
    I have this 14Gb MPEG2 (DVD-ready) video file that I captured from a TV program. I would like to remove the commercials and only keep the programming portion altogether.
    To this effect there are many programs to cut and rejoin, I have tried Honestech editor but it's really slow. What is the fastest/best software to do this and that will preserve the original video/file parameters and format?
    Thanks.
  2. Womble's MPEG2VCR or MPEG Video Wizard will do what you want without re-encoding. Very fast, too.
  3. Freeware that can also cut/join MPEG without re-encoding (but not down to the exact frame) are Cuttermaran and MPEG2Schnitt
  4. Member ZippyP.'s Avatar
    You can also do simple editting with TMPGEnc DVD Author (TDA) and then author and burn the file, all with the same program.
    Thanks, I will try Womble MPEG Video Wizard. One more question: I have this 14Gb TV MPEG2 video file in an external USB2 hard drive. The Womble editor program will be installed in the C drive. What location should I choose for the source and target file to optimize speed and load on the system? Thanks.
  6. Member ZippyP.'s Avatar
    I usually find copying files to be faster if the source and target are on the same drive. Your mileage may vary.
  1. Fastest way to create segment from video file?
    By therock003 in forum Editing
    Last Post: 2nd Mar 2012, 13:56
  2. Replies: 2
    Last Post: 10th Aug 2009, 07:46
  3. Replies: 2
    Last Post: 4th Mar 2009, 13:20
  4. convert hd pal mpeg2 file to hd ntsc mpeg2 file
    By gearo in forum SVCD2DVD & VOB2MPG
    Last Post: 5th Jun 2008, 01:12
  5. DVDripping everything good up until rejoin
    By Xplic1T in forum DVD Ripping
    Last Post: 10th Jul 2007, 23:26
