Im trying to burn a 99min cdr and I have done so successfully several times in the past with nero and my lite-on 24x burner. However, now for some unknown reason when I try to overburn a cdr, it keeps ejecting my cdr and telling me "Please insert another medium that provides more space" and doesnt give me any option for overburning. I enabled it under the Expert Features and the max overburn size is greater than the file im trying to overburn. Also, I have the DAO option selected and its still not working. Whats wrong here? Did i accidentely deselect/select an option thats giving me this problem? Please respond ASAP
I would bet that you updated nero and then it quit working. Nero had a problem with one of thier later release. Get the latest release and it will cure it.
I just upgraded from 5.5.4.0 to 5.5.5.1 and it didnt work again. So I tried decreasing the file size by 3mb, and now for some reason it started to work again. I dont get why this happened. Does nero have a restriction on far I can overburn even with the overburn settings i choose? Does this mean that if I wanted to try burning 100+ minutes onto a cdr, it wont let me? Well, at least its working now.
Definitely download the latest version of Nero, until then, when the disk is ejected just push it back in and the dialog box asking to overburn should come up.
Just posted after you. Re-inserting the cd tray probly won't work then.
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Problem with ejecting disc
By blup_00 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 22nd Jun 2010, 03:48 -
Panny AG-1980 makes a squealing sound while rewinding and ejecting tapes
By OldMedia in forum RestorationReplies: 4Last Post: 4th Apr 2010, 07:49 -
LG IH-E9674 not ejecting or reading
By kurt99 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Nov 2009, 09:37 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 01:20
