I used DVDFab to create an image of a DVD-9 Disc to burn onto two DVDs. But the files are:
Disc1.iso_0
Disc1.iso_1
Disc1.iso_2
Disc1.iso_3
Disc2.iso_0
How do I burn that?
Thanks.
I know nothing about DVDFab, but how many total gigabytes are all of those files. About 4.3 gig or 7.9 gig? Do all of those files comprise only 1 whole DVD-movie?
That happened 2 me too. Which version are you using?
DVDFab has a burning engine under tools at the start-up screen (assuming you have the pay version and you update it to 1.95 if necessary). Most likely Disk1.iso_0 - Disk1.iso_2 are old images becuase you did not burn or did not have delete image after burning option checked. Disk1.iso_3 and Disk2.iso_0 is most likely what you want to burn. Check the timestamp on the files to see if I am correct. Unless the timestamps of Disk1.iso_0 - Disk1.iso_3 are close they were created by seperate runs. I would also guess that could rename the files and burn as a standard iso. IE movie1.iso and movie2.iso.
Mark
I tried DVDFab myself to split a DVD9 to 2 DVD-R. I got the same results; a folder full of 1GB files instead of 2 complete ISO's. But if you burn w/ DVDFab, it works sort've like a multi-part RAR archive. You select the ISO_0 file for the first disk and it burns all the parts for that particular disk image. Certainly a weird way to make an archive (split instead of single ISO), but it works.
HP: Transfigura! PM: Mr. Potter, what in Merlin's name is that?? *Gestures at white VW bug w/ a "53" on it.* HP: Well, professor, you did say to make a Beetle! PM: Hmmmpft! HP: My muggle cousin was watching "The Love Bug" before I left!
Recordnow does that as well, when it makes an image of a disc it creates a series of 1GB files called image_11.gi, image_12.gi, etc.
Most likely this is done to maintain Win9x compatibility, due to their filesize limitation.
- Gurm
Didn't think of that last night, but that would be logical.Originally Posted by Gurm
how do you make an .iso file using dvdfab hd decrypter?
By Beautiful Alone in forum DVD RippingReplies: 41Last Post: 15th Aug 2011, 05:38 -
Using DVDFab to make ISO file from BD?
By neworldman in forum Blu-ray RippingReplies: 1Last Post: 5th Apr 2010, 05:40 -
DVDFAB Platinum 6 . . . need a basic primer for 1) CUSTOMIZE + 2) save ISO
By MISS CHIEVOUS in forum DVD RippingReplies: 14Last Post: 25th Oct 2009, 14:32 -
DVDFab HD Decrypter: no ISO created!
By taboo in forum DVD RippingReplies: 8Last Post: 5th Apr 2009, 22:25 -
DVDFab HD Decrypter and BD iso
By rhegedus in forum DVD RippingReplies: 5Last Post: 13th Oct 2007, 05:13
