How does one uninstall the Windows Media Player? Mine quit working and when I try to reinstall it windows says that I have the latest version and won't let me continue.
In Windows XP:
Start -> Settings -> Control Penal -> Add or Remove Programs -> Windows Medial Player
Done.
In Windows 95/98/Me/2000...
Next time
Thanks for your reply vioxx. The reason I posted the request is because windows media player does not appear in control panel. Iam using winxp.
I've never done this but isn't there a 'repair' option when you insert the XP disk? Maybe you can just 'fix' it instead of removing it. I remember reading about this in the stuff that came with the program and thought that sounded like a good deal. Fortunately I haven't had to deal with anything like this, yet.
If it works, don't fix it.
Install Media Player Classic, or if you still want WMP, try 9. WMP9 is pretty good. A little heavy on resources but it plays awesome.
A bird in the hand is worth a foot in the tush-Kelly Bundy
start/settings/control panel/add-remove programs
click on "add remove windows components"
scroll to the bottom
That's in 2000, so you may not have it in XP
Windows 7 Media Center to use Windows Media Player for MKV
By pvong in forum Newbie / General discussionsReplies: 4Last Post: 31st Jan 2010, 10:26 -
WMA with markers & script does not work in Windows Media Player 11
By musomn in forum AudioReplies: 0Last Post: 16th Oct 2009, 09:24 -
Cannot encode DVD to work with Windows Media Center.
By Coldkilla9 in forum Video StreamingReplies: 0Last Post: 31st Jan 2009, 10:47 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 5th Jul 2007, 23:18
