VideoHelp.com Forum
  1. Hi everyone,
    I have been back up copy-protected DVD directly (rip & burn) with elby CloneDVD for many times now.
    The CloneDVD can rip then burn the copy-protected DVDs (with the help from DVD Region-Free or AnyDVD) all-in-one.
    I try InterVideo DVD Copy to do the same.
    I try to run InterVideo DVD Copy by self, or with DVD Region-Free then AnyDVD running in the back ground. All the time InterVideo DVD Copy told me that 'Can not copy copy-protected DVD'.
    Is any program running in the back ground to let InterVideo DVD Copy platinum to rip & burn copy-protected DVD directly?
    Thanks...
  2. Dvddecrypter is free and wiil uncopy protect any dvd you care to try. Use the file mode and check all files and when its done you'll have a folder you can import that will work just fine. Nyah Levi
  1. Copy Copy-Protected VHS to DVD
    By abazabam in forum Media
    Last Post: 12th Feb 2012, 02:25
  2. Copy of a Copy of a Protected VHS Tape to DVD
    By solarblast in forum DVD & Blu-ray Recorders
    Last Post: 18th Dec 2008, 07:36
  3. Replies: 3
    Last Post: 6th Oct 2008, 00:31
  4. Unable to copy copy-protected data DVD
    By J_Kirk in forum Computer
    Last Post: 22nd Jan 2008, 11:23
  5. Help, Problem with Intervideo dvd copy 5 platinum
    By heman28 in forum DVD Ripping
    Last Post: 3rd Jan 2008, 20:12
