Hi everybody,
Situation:
I have AVI + STR/SUB.
I put permament subtitles (VDub + Subtitler) and convert to .M2V and .AC3..
The .M2V is HD1/KDVD so I can hold up to 5/6 movies in one DVD-R.
Then author with TMPGenc DVD Author.
That is what I need to do :
I need selectables subtitles !!!
I read the guide "How To Backup a DVD and Add new Subtitles to a DVD. (THE COMPLETE WORKING GUIDE)." it is excellent, but I have different movies-subtitles, not just one movie or VOB.
Is it possible ?
How?
Thanks in advance!
use dvdauthorgui or dvd-lab pro or ulead dvd workshop 2. use subtitle workshop to convert between subtitle formats.
to use selectable subtitles you cant use Tmpgenc dvd author. Ive read that guide you are saying and it is really great. using rejig or ifoedit, if you cab¿nt purchase softw<are like dvd-lab, maestro or other, I think there is a guide around there which explain how to put several movies authored with rejig and ifoedeit in one disk. Read something about renaming the .vob files vts_0_1.vob of the second movie and changing it to vts_1.1.vob and so forth. kepp looking and youll find this guide.
Thank you Baldrick , you're always there!!!
Yes, I've tried dvdauthorgui and it works as expected.
The only problem I've found is with my AC3 from VDub, NunDub.
I got this error :
DVDAuthorGUI 0.984 - 5/18/2004
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [???] File D:\video\DVD-RIP\Blade_Runner\BR.m2v looks like an MPEG Video stream.
**ERROR: [???] File D:\video\DVD-RIP\Blade_Runner\br1.ac3 unrecogniseable!
**ERROR: [???] Unrecogniseable file(s)... exiting.
*authoring title(s).....
DVDAuthor::dvdauthor, version 0.6.9 SvG11.
Build options: gnugetopt magick iconv freetype fribidi
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing D:\video\DVD\dvdauthor\br\title1.mpg...
ERR: Error opening D:\video\DVD\dvdauthor\br\title1.mpg: No such file or directory
No se encuentra D:\video\DVD\dvdauthor\br\*.mpg
*authoring process complete.....
The AC3 header said:
File: D:\video\DVD-RIP\Blade_Runner\br1.ac3
File size: 0 bytes
AC-3 File type: SMPTE time code (0x00)
Total frames: 0
Frame size: 0 bytes
Sample rate: 0 Hz
Data rate: 0 kbps
Audio coding mode: 1+1 (L, R)
Bit stream mode: Main audio service: Complete main
Dialog normalization: Reserved
Center mix: -3 dB
Surround mix: -3 dB
Copyright: Off
Original: Off
Start time: 00:00:0,00
End time: 00:00:0,00
Status: Frame 1
Unknown frame type
I looked here and I found AC3FIX that seems to be my solution.
I'll try ...
THANKS!!!!!
Mike
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
What am I doing wrong? AVI to DVD with srt subtitles.
By du2vye in forum ffmpegX general discussionReplies: 8Last Post: 21st Oct 2009, 12:54 -
Question how to make srt/avi subtitles bigger when playing in DVD player
By jimdagys in forum SubtitleReplies: 6Last Post: 24th Oct 2008, 00:10 -
DVD to *.avi rips with *.srt subtitles
By WhiteFox in forum Video ConversionReplies: 0Last Post: 3rd Sep 2008, 10:51
Hi everybody,
Is it possible ?
