VideoHelp.com Forum
    I am going to send some of my NTSC home videos to my PAL relatives. So, it needs NTSC 8mm tape converted to PAL system. Since I cannot check my final product here, I need your advice on the conversion process that might actually work. Here is the process I was thinking to try:
    1. Using Canon 8mm camcorder, capture AVI source at 688x480 with iuvcr (Thanks to John “FulciLives” Coleman advice since my capture card is AverTV stereo card with official driver and iuvcr is the only program that let me capture more than 352 x 240 with interlaced field);
    2. Convert AVI source in NTSC to PAL system with TMPGEnc plus. For this I am going to use the guide from here: http://www.videohelp.com/forum/viewtopic.php?t=222898.
    2a) The problem is how to “padd” the capture with 16 pixels of black on the left and 16 pixels of black on the right to make the width 720 (need some real help on this one). Here is my setting:
    VIDEO Tab:
    Stream Type: MPEG-2 Video;
    Size: 720 x 576 (for PAL)
    Aspect Ratio: 4:3 (I have already tried 16:9, in which picture looks fat and short)
    Frame Rate: 25
    Video Format: PAL
    Advanced Tab:
    Video Source Type: Interlaced
    Field Order: (As determined by TMPGEnc during “Wizard” run)
    Source Aspect Ratio: 4:3 525 line (NTSC)
    Video Arrange Method: Center (keep aspect ratio)
    Is my setting correct? If yes, how and where the “padding” is enabled?
    Appreciate any help guys.
    EEBA
    OK. I was doing little search and found something that might help my case.
    From here: http://www.geocities.com/xesdeeni200...rdsConversion/ got the AVI script to convert NTSC 29.97i DVD to PAL 25i DVD.
    LoadPlugin("MPEG2DEC.dll")
    LoadPlugin("SmoothDeinterlacer.dll")
    MPEG2Source("DRIVE:\PATH\VTS_xx_x.d2v")
    SeparateFields()
    Weave()
    SmoothDeinterlace(doublerate=true)
    ConvertFPS(50) # or ChangeFPS(50)
    LanczosResize(720,576)
    SeparateFields()
    SelectEvery(4,1,2)
    ConvertToRGB()
    However, mine is NTSC 29.97i AVI source at 688x480. So to me, “MPEG2Source” is not applicable. I will replace it with “AVISource” command. What else needs to be changed here?
    EEBA
    Could some post AVI Script to convert NTSC interlaced source captured at 688x480 to 720x576 PAL DVD?
    EEBA
    After little research, I find a way to convert my 688x480 to 720x480, by adding 16 pixels to right and 16 to left. Here is the AVI Script
    Avisource("MyCapture.avi")
    AddBorder(16,0,16,0) # converts 688x480 to 720x480
    SeparateFields()
    Weave()
    LanczosResize(720,576) # resize to PAL resolution
    SeparateFields()
    SelectEvery(4,1,2)
    ConvertToRGB() (TMPGEnc) or ConvertToYUY2() (CCE)
    Can some one check my script? Is there anything need to be changed?
    EEBA
  1. 8mm Pal to NTSC
    By GR8LAKER in forum Newbie / General discussions
    Last Post: 16th Mar 2011, 07:48
  2. 8mm tapes PAL with NTSC camcorder????
    By igorv in forum Capturing
    Last Post: 11th Oct 2010, 13:17
  3. Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
    By scotty123 in forum Video Conversion
    Last Post: 9th Oct 2009, 12:49
  4. Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
    By scotty123 in forum Newbie / General discussions
    Last Post: 3rd Oct 2009, 00:34
  5. PAL VCD -> NTSC Video for NTSC DVD Authoring!!
    By Mickey79 in forum Video Conversion
    Last Post: 12th Aug 2008, 11:30
