I'm using the newest DVD Decrypter and CopytoDVD. The DVD will play with PowerDVD but not on any DVD player's. If I use CloneDVD just run the DVD in cloneDVD and burn the DVD it work's with no problem.. IF I rip with Smartripper if will not even play on the PC. Thanks.
This is one reason I don't like Panasonic recorders. They tend to foul up the files, especially AC3 and the multiplexing of the files.
DVD Decrypter (I use 3.1.8.0 and 3.1.9.0) in IFO mode to grab the recordings as they were recorded. Then rip streams to HD. Next, use VOBEDIT to properly pull out the audio. Again for the video. If the video is corrupt in any way, Restream it real quick, enabling all the "correction" options you see (video normally fine). Now you've got proper files to work with.
If this is VR mode, a bit harder. I can only use ISO Buster to pull out one big VRO file (no IFO mode, just a single file, regardless of the number of titles it may be). I'm not sure how well your -RAM writer gives you control when it mounts a drive letter for you. For you, the IFO method may or may not work.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
there are a number of posts that talk about the issues with the panny and playing on a number of different dvd players. All of my panny work is for home movies, where I need to make menus, chapter cuts, etc. What I do is use TMPGENC DVD author to rip/"convert" a vro file to dvd. After doing this, every dvd player that would not play the original, plays the new version correctly.
need your help on BD ripped movie on Panasonic BD60
By yd8552 in forum Blu-ray RippingReplies: 2Last Post: 2nd Nov 2009, 15:50 -
Writing ripped blu-ray films to read them on Panasonic DMP-BD35
By vanhovb in forum Blu-ray RippingReplies: 0Last Post: 26th Jan 2009, 06:53 -
Can't watch ripped movies on Panasonic DVD-F87
By arbutler in forum DVD RippingReplies: 5Last Post: 13th Oct 2008, 18:40 -
Panasonic DMRES45V DVD remote doesn't work correctly
By cep8719 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2008, 11:00 -
DVD-R discs work and then fail in Panasonic DMR E85H
By herefordjw in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 11:09
Statistics
Newest guides
Latest tool updates
New media comments
