Hi,
I'm not sure if i put this in the right section of the forums....so sorry if im off. but i am building a new computer and i was wondering if anyone knew of any graphics cards that are good for just video editing. I have been editing for awhile now...so i already have a firewire card and all that, so i dont need it to capture video. I read that i should be looking for something that can do Mpeg and realtime stuff? i did find this card by MSI...FX5600XTVTDR128....http://www.msicomputer.com/product/p...R128&class=vga and am thinking about it cause it recieved editors choice by tomshardware...but not really sure if it will do what i want. So anyway im on a little but of a budget and need to keep it around $100 if possible, oo and i would also like to have support for duel monitors. thanks for all the help...greatly appreciated![]()
Results 1 to 10 of 10
Thread: Graphics card for video editing?
ATI All In Wonder card
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
http://www.compusa.com/products/prod...024&pfp=SEARCH
$150 after $20 rebate, but has the TV tuner and dual monitor output..
Alan
What a coincidence..... I was at Micro Center today having a new 250GB hard drive installed, & I was going to have this graphics card installed also. I started talking to one of the tech guys & he said to wait until the end of the Summer to upgrade on any graphics card, because there has been a big advancement on the video memory barrier & the cards are about to go through the roof performance wise.Originally Posted by Carkey
Boda
This doesn't really apply to capture cards.Originally Posted by BodaZoffa
what graphics card you use for video editing makes no diff. what so ever ...
except if you use a app that uses opengl (boris red for example) , then you need a opengl card ...
matrox are popular for video editing because of the 3 head design (one of which can be ntsc/pal out or pc monitor) and great color rendition and stablity ... ati and nvidia are just as popular.
dont spend a lot of money on a graphics card if it is a NLE machine only ..or if you dont need 3 outputs ..
REAL TIME video editing doesnt rely on the graphics card but on a dedicated seperate card ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I would suggest a Matrox P750, or a G550, depending on your needs. Excellent TV out, multihead, and fast and stable for 2D needs such as video editing.Originally Posted by Carkey
The P750 has three out, which can be three monitors, or two monitors and a TV.
The G550 has two out, which can be two monitors, or a monitor and a TV.
I have both cards, but I think the P750 is a better card.
http://www.matrox.com
I also have an ATI A-I-W 8500DV, which is very nice, but the TV output from the Matrox is clearly better than the TV output from the ATI card. AT this time, the ATI card is in a PC dedicated to PVR - I no longer use my VRCs at all.
Thanks for all the intput...it has helped alot....so now i am stuck between the ATI AIW 9600 and The Matrox Millennium P650? which do you think will do the job better?
as i stated -- neither one will do video editing "better" ..
but one factor is that the ati will have better mpeg decoding onboard and the matrox is better for color .....
i use matrox cards exclusivly for triple screen- but i would not kick any one of the better ati or better nvidia cards out of bed either ..
I have tried an ati card (not sure which one) and for sure it played HD mpeg files smoother"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
supposedly the upcoming nivida card will have an onboard mpeg encoder
on it. that could prove interesting. I think ATI is tossing one on as well.
Video Editing Laptop Graphics Card
By tqw1315 in forum ComputerReplies: 3Last Post: 29th Aug 2010, 01:34 -
best graphics card for s-video out?
By Statick in forum Media Center PC / MediaCentersReplies: 10Last Post: 9th Feb 2010, 09:09 -
Recommendation on a graphics card for .MTS video editing and viewing
By Zetti in forum EditingReplies: 0Last Post: 12th Dec 2009, 23:07 -
Graphics card for video editing. ATI or Nvidia?
By vid83 in forum ComputerReplies: 2Last Post: 6th Feb 2009, 15:29 -
New install, new graphics card...no video
By bluehere in forum ComputerReplies: 3Last Post: 26th Feb 2008, 12:09
