VideoHelp.com Forum
    What is the best software to use to trim the mpegs so that the join is in sync and does not step back
    Many thanks
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I think it depends on the method you use to author. I use TMPGEnc DVD Author and I just put the two parts of the adjusted SVCD into it as seperate videos and let them play one after the other. There is a 2 second or so overlap from the original DVD2SVCD files that is barely perceptable, but it could be easily trimmed in TDA by adjusting the end point of the first file.
    Refer to this thread.
  1. Help please with Aiseesoft trim function,
    By cromwell in forum Newbie / General discussions
    Last Post: 18th Mar 2012, 14:28
  2. About TRIM and Subtitle
    By DruidCtba in forum Subtitle
    Last Post: 3rd Feb 2011, 10:52
  3. AVI Trim
    By drgt in forum Newbie / General discussions
    Last Post: 13th Nov 2010, 04:36
  4. easiest way to trim captures ?
    By Tafflad in forum Capturing
    Last Post: 14th Feb 2010, 14:24
  5. How to trim wmv-hd?
    By daz2712 in forum Blu-ray Ripping
    Last Post: 26th Aug 2009, 09:55
