Hi,
Is there a tool to automatically split the AVI file I capture from a
camcorder into multiple files based on the scene change, and name the
files according to the time and date. One tool that I used to use is the
scenalyzer, it seems like it is not supported aymore. the sclive does not
seems to be able to do the avi splitting feature.
Hi singkarak,
VirtualDub won't detect scene changes, but it will split AVIs for you and you can manually dictate where it will do it. All you need do is to identify where you want the splits and do them manually.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Thanks for the input.
That will be very time consuming, Just wonder if there is automatic tools
to do this.
Singkarak.
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
How do I split a video into multiple files?
By chipped in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2008, 05:33 -
Program to manually split multiple parts of same avi?
By majax79 in forum EditingReplies: 5Last Post: 22nd Dec 2007, 10:49 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 23rd Aug 2007, 12:49
Statistics
Newest guides
Latest tool updates
New media comments
