Im just starting backing up my dvds. should I rip the dvd and save it on my hard driveas the 7 gigs or should I just use dvd shrink to save it as the shrink size. will I be able to edit more audio and chapter after I use shrink if I want to make better copys later in life. I plan to save all my movies on my hard drive and keep the collection on external drives.
Thread: backing up dvd
must don't have that many dvds if you want to save them on hard drives?
How Big A Boy Are Ya?
Either way is fine. If you rip with DVD decrypter you save everything exept the copy protection to your HD.
With DVD Shrink if you leave parts out then obviously those parts are gone. However you can shrink as many times as you like and either just add more compression each time or remove more bits each time.
You miust have a fair amount of HD space if you are going to store lots on HDs .
Another way to keep back ups and keep a lot of quality is to convert the main movie and the main audio track to Mpeg4 (something klike Xvid) .
That way a good quality DVD Rip will take up around 700MB.
"Learn from other people mistakes , it's quicker"
I have a removable HD bay with 3 X 200GB drives I rotate in and out of it. I use one to store ISOs of my XBOX games, one to capture and edit footage from TV/VHS, and the other to trade caps and other assorted stuff with mates. Cost me a little bit but a pretty good setup IMO. I have contemplated using one exclusively to store images of my 35 commercial DVDs.
If in doubt, Google it.
I have pretty much settled on having 4.7GB the max for a long time. No DL plans for me. So I just keep the shrinks. Of course, my hard drive is way too small but even when I buy a new hard drive, I will still only keep the shrinks.Originally Posted by dmb23
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Need help backing up dvd on a mac
By pibrew in forum MacReplies: 1Last Post: 23rd Aug 2011, 16:22 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 09:15 -
Backing up Region 3 DVD
By javajeep in forum DVD RippingReplies: 5Last Post: 28th Jan 2008, 23:55 -
Trouble Backing-Up DVD...
By LCE in forum DVD RippingReplies: 7Last Post: 1st Nov 2007, 00:38
