can someone please guide me to the right section, i'm looking for why my vcd won't fit onto a cd after nero has encoded it, thanks
Thread: right section
Its too big, make it smaller
how many MB is your VCD? you can either make it smaller by splitting or use the overburn feature of Nero though not being advised by Nero...
hacking the Net using typewriter :D
the mpg file is 734, but when encoded by nero to burn it ends up being way to big, it doesn't let me overburn, it just says that it won't fit
Why is Nero trying to encode your mpg-file? How big is the file after Nero encodes it?
It sounds like you have a DivX/Xvid AVI file and then nero encodes it to VCD which will create a much bigger file, but you say you have a mpg-file.
734 Mb should fit with no problem at all. Have you enabled overburn in Nero?
// Znooky
i have no idea, it seems to be about 200 meg more then what i started with, it's an xvid avi file which i converted to an mpg file, which is 734 mb, but some some reason nero doesn't recongise it when burning a vcd, i converted it with tmpgenc, have enabled overburning
Well, that's perfectly normal. A AVI-file in lets say 90 min encoded with xvid is much smaller than the same file encoded with mpg-1 VCD. This is becuase xvid compress the file much more than VCD. You can fit 80-min video on a 700 Mb CD-R in VCD-format.
Since your converted file is to big to fit on a 700 Mb CD-R, I suggest you split it in two parts using TMPGEnc and then burn it with Nero.
// Znooky
n00b looking for right section
By shiroshadows in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2009, 09:38 -
Movie section only
By andreltr in forum LinuxReplies: 8Last Post: 6th Jun 2009, 04:18 -
Replaying a 10 min section
By elute96 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 14:03
