Results 1 to 12 of 12
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    I was thinking of getting the Hauppauge Nova-t. We have some free dvb-t channels in sweden and it would be fun to test it.
    http://www.videohelp.com/capturecard...d=244#comments
    http://www.tv-cards.com/nova-tpci.php
    it seems to work some 3party tools also like mytheatre. and you can use the technotrend drivers.
    Should I buy or do you recommend some other dvb-t cards?
  2. Member flaninacupboard's Avatar
    the 2000-t USB box looks good, you can connect to PC via USB and also connect to your TV.
    i opted for a humax pvr-8000t box. DVB receiver with 40GB hard drive, very pleased with it
    I don't need to connect the card direclty to a tv. I already have a xcard so I can play the captured material on the tv. And maybe will joveplayer, a xcard video player, support dvbt in the future so I can view live on the tv(it now only support dvbs using mytheatre).
  4. Member flaninacupboard's Avatar
    i think i would still go for a USB version, easy to swap to another PC if needed and won't tie up your system if you're capturing a show to watch later.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    or maybe the twinhan card
    http://www.twinhan.com/visiontv-1_6.htm
    I just want a cheap card. It is mainly for testing digital tv.
  6. The Old One SatStorm's Avatar
    SkyStar 2
    Don't even look elsewhere....
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I don't have any place for any satellite dish.
  8. The Old One SatStorm's Avatar
    Not even for a 40cm one? Attisat design?
    Anyway:
    Hauppauge has great German support. Officially and unofficially.
    I also know, that it used to sell a lot in Berlin, 'cause there, they have only DVB/T, they don't have analogue terrestrial transmissions anymore!!!
    I don't know about twinhan. It looks excellent and maybe is, but I don't know about it.
    Baldrick, don't buy the Hauppauge card, it is absolute rubbish. I know, I used to own one. Check out the Nebula card instead. I know its more expensive, but its ten times better. I use it a lot for grabbing DTT in the UK.
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    I have also checked it out and it get good reviews. But can you use it with other dvb software also?
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    i think I will wait...not many dvb tools supports dvb-t cards
  12. Originally Posted by energy80s
    Things have changed a lot in the past year or so with the Hauppauge/TechnoTrend cards. The version 2.xx software is rock solid and provides EPG, subtitles and scheduled recordings, something missing from the earlier software.
    People are having HUGE problems with the Nebula cards too, and their technical support has been declining recently, while Hauppauge UK are more responsive.
  1. Replies: 0
    Last Post: 20th Mar 2007, 11:17
  2. Replies: 3
    Last Post: 8th May 2006, 19:04
  3. Replies: 5
    Last Post: 11th Nov 2003, 04:08
  4. virtual dub and hauppauge nova-t
    By atrox178 in forum Capturing
    Last Post: 12th Jul 2003, 17:00
  5. Replies: 0
    Last Post: 24th Mar 2002, 14:10
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
