VideoHelp.com Forum
  1. i read a messag here from a user that wants to record from PAL signal on ntsc dvd recorder & here's the answer he's got that he only needs a pal tv tuner. here is the message:
    i can only connect the dvr to cable box through coax cable, and the channels i get are black/white no sound.
    What you need is a PAL TV tuner since your Cyberhome DVD recorder only has an NTSC tuner. The easiest way is to get a cheap or used VCR with a PAL tuner locally, then connect the cable box to the VCR through the coax cable, and connect the VCR output through the RCA cables to the DVR's input jacks, finally make sure the DVR's output is switched to PAL. That should work although a little awkward.
    is there a question in there somewhere? :P
  1. (pal) LG RHT497H - Can it record NTSC?
    By dave_van_damme in forum DVD & Blu-ray Recorders
    Last Post: 18th Nov 2009, 11:59
  2. Replies: 2
    Last Post: 17th Jan 2009, 14:36
  3. PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
    By quantass in forum Newbie / General discussions
    Last Post: 12th Dec 2008, 13:47
  4. PAL VCR with true NTSC Output (not PAL 60)
    By Area88 in forum Restoration
    Last Post: 12th Aug 2008, 17:55
  5. How to record NTSC on a PAL dvd recorder?!
    By Dekaspace in forum Newbie / General discussions
    Last Post: 3rd Jul 2008, 23:21
