VideoHelp.com Forum
  1. MODS - Apologies if this is in the wrong forum. Please move if needed.
    Just wanted to give my thanks and appreciation for this great site. With the guides and knowledge available on this site and in the forums, I was able to successfully encode and burn a 6 episode disc (6 - 45minute DivX files) complete with a menu and Play All function.
    For the record, I used Main Concept 1.4 for the encoding (Files were PAL - converted them to NTSC 352x480, VBR - 5000 max, 300 min, 2500 average) using mp2 audio (all of my players support this). I used DVDLab for the authoring and menus, IFOEdit to add the Play All function, and DVDShrink to fit it on a DVD-R (total was slightly over 5GB, and I noticed no change from the encodes to the Shrink re-encodes). Total project time was about 6 hours (about 2 to learn and read the guides) and I am super pleased with the results.
    So for all those that make the great guides - your work does not go un-noticed!!!
    Now I can start authoring that band DVD I wanted to do...
    Thanks again,
    -Ceedj
  2. Member flaninacupboard's Avatar
    Good to hear you got the info you needed. hopefully you can stick around to help out those who don't find it as easy to get to grips with as yourself...?
  3. Congrats!
    I still remember my first success of burning a disk. It was very exciting.
    Good luck with your band!
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  4. Член BJ_M's Avatar
    i remember my first success at .. wait , wrong forum
  5. The Old One SatStorm's Avatar
    The first time I grabbed a DVB transmission, it was 1999. I was so excited...
  6. Member sacajaweeda's Avatar
    Don't be shy now...
    http://www.videohelp.com/donate
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  1. My first impression of videohelp.com
    By svejkovat in forum Feedback
    Last Post: 20th Jan 2012, 16:28
  2. I just wanted to thank VIDEOHELP.COM :)
    By MISS CHIEVOUS in forum Feedback
    Last Post: 18th Sep 2009, 02:29
  3. How Can I Get VideoHelp To Look Right?
    By DarrellS in forum Feedback
    Last Post: 20th Jul 2009, 04:38
