VideoHelp.com Forum
    Would be nice to be able to make DVDs with the vcdeasy software.
    I work with alot of video clips about 100-300 mb, and putting them all on a DVD would be nice!
    Comments (?)
  2. Videoclips in VCD or SVCD format is not the same as DVD. You can put your videoclips on a DVD and burn it as a Data-DVD, but you won't be able to play that disc in your standalone DVD player.
    About your suggestion to make DVD with VCDEasy. Yes it would be great, but the videoclips would most likely to be converted to DVD format before they could be burned. To me it looks more easy to write them just as VCD or SVCD.
    Personally I really like VCDEasy because it very powerful in making VCD and SVCD. There are other programs for making DVD, so I really don't need a DVD ability in VCDEasy.
    // Znooky
  3. You can burn VCD compliant files on DVD, but need just convert audio from 44kHz to 48. ...thats all. In most cases it will be DVD compliant disc. Very simple way is using Tmpeg DVD AUthor. I've made Indiana Jones all 3 parts on 1 DVD, using kvcd templates, near DVD quality.
  1. Suggestion to make the video look better?!
    By SB4 in forum Restoration
    Last Post: 18th Sep 2010, 19:14
  2. Suggestion for DVD-R recorders
    By dbldecue in forum DVD & Blu-ray Recorders
    Last Post: 27th Oct 2008, 20:08
  3. Replies: 4
    Last Post: 17th Mar 2008, 10:40
  4. How will I make an AVCD using VCDEasy?
    By zeldAIS in forum VCDEasy General
    Last Post: 4th Aug 2007, 15:13
  5. Need DVD Recorder Suggestion
    By Mr. Burn in forum DVD & Blu-ray Recorders
    Last Post: 28th May 2007, 10:57
