VideoHelp.com Forum
  1. dont ask me how it's been that way.
    i got an asf file but the extension is avi instead. i want to convert my file into mpg by tmpgenc but it shuts down because it has a wrong extension.
    if you open it by searching avi files it will open ofcoure but it is still in asf format once you play it.
    is it possible to change the extension into *.asf? if it is how?
    what encoder can convert this kind of file into mpg?
  2. Member stackner's Avatar
    i have had the same thing happen. the only program i know of tha will let you edit asf files is virtualdub 1.3c with the asf patch. this is an old virtualdub but modern vers won't work. this will atleast let you convert to avi or frame server to a program for mpg.
    cheers
  3. Member teegee420's Avatar
    You can find a link to Virtualdub 1.3c on this page. I'm hoping that you have better luck than I did because it has never successfully worked for me. There's always an error when trying to parse the asf.
  1. Can't get video back to its original file version without the avi extension
    By writersblck in forum Newbie / General discussions
    Last Post: 15th Jan 2012, 13:03
  2. suspisious ASF-AVI file
    By roberta in forum Video Conversion
    Last Post: 15th Aug 2010, 16:18
  3. .G64 (File Extension) to AVI / WMV
    By Rhinestone in forum Video Conversion
    Last Post: 4th Oct 2009, 11:08
  4. New File Extension To Convert
    By EDS001 in forum Video Conversion
    Last Post: 20th Mar 2009, 16:59
  5. wht is the .ff file extension
    By modular1 in forum ffmpegX general discussion
    Last Post: 9th Oct 2007, 05:05
