Just got a new samsung HLN467W Tv and i am going to get comcast cableHD.Do i use compoent inputs or the DVI input?Am i going to see a difference?I am new to this and need all of the help i can get.Thanks
Thread: DVI or component?
Use the DVI output.
DVI is likely to be better. There might be colour differences, eg brightness, which might make one look better than the other. Only your eye will be the judge of that.
"speed's just a question of money. How fast can you go?" - Mad Max, 1979
Check this thread with the same topic earlier this year:
http://www.videohelp.com/forum/viewt...=dvi+component
dvi vs component cables
By consumer567 in forum Newbie / General discussionsReplies: 6Last Post: 29th Dec 2009, 16:06 -
tv out(dvi to component) problem
By tseizaL in forum DVB / HDTVReplies: 30Last Post: 25th Dec 2009, 08:22 -
DVI to Component
By Darth Paris in forum Media Center PC / MediaCentersReplies: 1Last Post: 10th Jun 2009, 11:13 -
DVI/Component cable
By ajcstr in forum DVB / HDTVReplies: 9Last Post: 16th Oct 2008, 05:25 -
Using a DVI to Component adapter?
By videonewbie69 in forum DVB / HDTVReplies: 15Last Post: 2nd Aug 2007, 05:17
Statistics
Newest guides
Latest tool updates
New media comments
