Hi,
I am trying to get my head around this WinTV PVR card i've just been given and have a couple of questions.
I understand that to create a SVCD i have to capture to 480x576 mpeg2( for pal )yes? Ok. Well my PVR is the USB version and i don't seem to be able to find anywhere in the settings the abilitly to record at this resolution. I only have 4 options available 1 mpeg1 at 1150Kb, and 3 mpeg2, at 2Mb,4Mb,6Mb at half D1 (D1?) and that is IT, nothing else to play with at all. I need to record a 30min clip and i have experimented with the 4 options and should be able to use Mpeg2 2mb to create a managable size clip of about 480Mb. Only problem is the clip is at 352x576 res, ( I think, i'm at work at the mo, and my brain is to far gone to remember that much detail ). Can someone point me in the right direction now pls? I would like to drag and drop this file into nero to create a SVCD but i think i'm missing something....
I have downloaded FlaskMpg, DVD2AVI, and various other utils which i have messed about with but i am kinda lost. Am i right in thinking that i have to stick with the software that came with the PVR to make use of the hardware encoding feature? Help!!
Thanks for your time....and apologies for the large post.
Specs are
P3 1000 CPU
Abit Sa6R Raid Motherboard
Hauppauge WinTV PVR Usb
1x Fujitsu 13Gb IDE66 Hdd
1x Fujitsu 20Gb IDE66 Hdd
512 Mb PC133 SDRam
Geforce 2 Gts 32Mb
Sb Live! Value
Dxr2 DVD Decoder
blah blah blah
oh and Win XP Pro
Kall
Results 1 to 1 of 1
Thread: Capturing with WinTV PVR Usb
better unit than my old wintv pvr usb2
By diablo in forum CapturingReplies: 0Last Post: 9th Sep 2011, 09:52 -
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum CapturingReplies: 33Last Post: 26th Apr 2011, 02:13 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum CapturingReplies: 4Last Post: 11th Feb 2011, 21:07 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 13:21 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum CapturingReplies: 10Last Post: 5th Mar 2008, 02:19
