is there anyway to get the video off a Hi-8 cancorder to PC or should i just leave this camcorder on the shelf and go out and buy a DV one?
Thread: hi8
2 ways --
capture it with a capture card or dv transcoder
or
put the tape into a digital 8 camcorder and transfer via firewire"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I wonder if someone will rent such a camera?
Only if the digital 8 camcorder supports Hi-8 analog format. Not all do. I think that most Sonys do.Originally Posted by BJ_M
Right and, typically, the lower priced Sony D8 models are not backwards compatible (example = TRV460 is while the TRV260 is not).Originally Posted by MpegEncoder
Go out and buy a TRV22 while they're still available and use its A/D passthrough feature.Originally Posted by vasta
You'll end up with what is, IMHO, a nice miniDV camcorder (at a good price) for future shoots and the ability to transfer all your Hi8 stuff to your PC without much of a hassle.
Help with Hi8 playback
By johnhudson922 in forum Camcorders (DV/HDV/AVCHD)Replies: 17Last Post: 30th May 2011, 21:58 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Hi8 encoding
By devin122 in forum Video ConversionReplies: 17Last Post: 17th Jan 2008, 11:41 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum CapturingReplies: 8Last Post: 22nd Dec 2007, 01:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
