VideoHelp.com Forum
  1. Member Sifaga's Avatar
    what gadget do i need to connect to my computer so i can record a FM radio programme.
    the programme runs for 2 hours and i would like for it to start recording automatically
    can record to any audio format as long as i can get it onto a CD (After editing)
  2. Member holistic's Avatar
    LINE OUT (typically RCA type) on radio or stereo receiver to LINE IN on your sound card (typically 1/8 inch phone type)
    Record in *.wav using any decent audio software.
    After recording use software to split up songs (chapters / breaks in broadcast)
    a thought Maybe virtual dub can do the recording . Use Virtual Dub to edit the portions you want and "direct stream" copy them.
    For the "recording automatically" there is a modded version of virtual dub that does TV it may work . will search for it.............
  3. Member Sifaga's Avatar
    wow , that easy
    thankyou very much
    i was expecting to buy some USB radio with some software
    come to think of it , its the same method as recording a cassette tape to my pc
    duh!!!
  4. Member holistic's Avatar
    No Probs.
    here for virtual dub VCR
    http://www.virtualdub.net/download.htm
    in German though !
  5. Member holistic's Avatar
    FYI - Just D/L and was playing witht that VirtualDubVCR
    It appears it will not accept wave files. It wants to open a video file.
    I will keep playing for a while.
    I use Blaze Audio Products. I hook up the sterio to the computer like holistic said. Use the porgram Power record, to record to the hd. It is programable as to time, and source. Then I edit out the comercials, and burn back to a CD.
    Thanks Mike
  7. Member MOVIEGEEK's Avatar
    www.cdwave.com or Audacity are good programs for recording to WAV/MP3/OGG.
  8. Member Roundabout's Avatar
    Both standard and pro editions of Total Recorder from www.highcriteria.com have scheduling and timer operations to begin and end your recordings automatically when you want. It can record in mp3, wav or ogg, your choice. I use it all the time and like this program a lot due to its simplicity and options. Price is low too, only $11.95 for the standard edition. Take a look and see if it will do what you need.
    Ethernet (n): something used to catch the etherbunny
  1. Replies: 2
    Last Post: 18th Apr 2011, 09:56
  2. Replies: 5
    Last Post: 1st Dec 2009, 17:46
  3. Programme picking help
    By zinc in forum Authoring (DVD)
    Last Post: 14th Nov 2009, 07:09
  4. How to record live radio and video streams?
    By Shadowofthedarkgod in forum Video Streaming
    Last Post: 15th Aug 2009, 19:40
  5. Replies: 5
    Last Post: 29th Nov 2008, 21:49
